TR6 Tr6 horns
TR3TR6
I'm replacing the horns on my TR6. After looking at there location, is there an easy way to do this, or will it require removing a bunch of things? Any input will be greatly appreciated.
DNK
Terry depends on what all is still there.
Basically just the front rad screen (shroud) should do it
trrdster2000
Terry, a two foot extension will help, couple of stabilizer bars and the shield should put you right there. A few people sell good horns and I used Griots, they are loud.
www.griotsgarage.com
Wayne
poolboy
If you have that shroud (air duct) between the front of the radiator and the back of the grill, remove it. You'll then have access to the mounting location for the original horns.
TR3TR6
TR3TR6
The shroud is in place, I could just see the horns from the front bottom of the car. I'll remove the shroud, wasn't sure I could get to them from the top. Thanks for the info.
I TR6 TR6 horns Triumph 10
I TR6 TR6 horns Triumph 0
I TR6 TR6 horns Triumph 5
I TR6 horns not working in TR6 Triumph 4
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
