Slight change of plans: I will install the doors before the top, to make sure the windshield is properly aligned before stretching the top to it. And installing the doors means the quarter panels to make sure everything is aligned
I’ve reassembled the passenger door; the drivers door was completed a while ago. Happy to say, I had very little trouble with the waist seal install, other than dropping a clip and losing it in the door (I found it after some good swears). I used a modified Home Depot tool plus a dab of grease to hold the clips to the tool.
I installed a new window regulator from Rimmers, and the windows rolls up and down very smoothly. Given this experience, I will replace the drivers side regulator with new, as it requires pulling up on the windows to raise. (Original regulator seems straight…not sure where the difficulty?)
I will attach a plastic barrier to the inside of the door, not hang it from the windows as originally.
The door check straps are new and installed without any extra effort. I’m not sure why mine went in easily, as I read several other folks who had great difficulty - removing material inside the a-pillar and bending the straps to fit. Maybe I did something wrong… but they work exactly as intended. (The original retaining clip is still in place in the door, I did not have to replace this. Also I installed the check strap with the front fender removed, this was able to open the door 90 degrees - maybe this helped??)
The door seals require a bit of muscle to close the doors; but even after one night the doors close much easier. Hopefully after a few months the doors will close “normally”. (TRF seals.) I cleaned the various door latch bits; they had quite a bit of gunk accumulated inside them!!
And this weekend I attached the first fender plus trim strip. Yay - staring to look like a car again!! (Still have some alignment to complete; two of the fasteners won’t go in. I am working slowly, I don’t want to scratch anything.)
