steve_sims
Member
Howdy All, Just bought a 63 TR4 that has been sitting since 1994. Cleaned out gas tank, replaced fuel lines, rebuilt carbs and she fired right up. Problem is crank pully wobble.When the bolt was removed, someone had added several washers to make up for either bolt being too long or old bolt broken off in crank. Hole in crank is only 1/2 inch deep. Threads on bolt are 1 inch long. Bottom of hole looks smooth, not ragged like broke bolt. Friend suggests we either cut off 1/2 inch of bolt threads or try to drill and remove old {broken} bolt. Any suggestions would be greatly appreciated. Thanks Steve
