Re: TR3A Park Brake Compensator Bar Assembly Pictu
karls59tr said:
Seems as if the compensator is supposed to stay stationary? What locks it in place to the axle?.... or do you just turn it in till it bottoms out? Mine is loose unless I need to crank it in another turn...will that put it at the 17 degree angle that the manual mentions?
Nope, the compensator has to be free to turn on both pivots. It won't turn, much, on the pivot attached to the axle; but it still needs to be free to do so.
The angle is not critical, it's just an observation. The angle is controlled by the length of the two lateral cables to each rear brake, which the factory manual says to adjust by measuring their length directly rather than worrying about the angle of the compensator.
BTW, the infamous Bentley is just a reprint of the factory workshop and owner's manuals. The owners manual in it is a very early edition and not quite correct for later cars. For example, it shows the wiring for the non-self-parking wiper motor, which will blow the fuse if you try to wire a later motor that way. Although they are less common than they used to be, genuine original manuals in tatty but legible condition do show up on eBay from time to time, for not much money. Think I paid $10 for the last workshop manual I bought (minus it's covers and first few pages).
Also BTW, cool photos, Don. Thanks ! Your attention to detail is just amazing; now I know why you have such good luck with your TR3A /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
