Hey folks, I bought a 1960 TR3A a few weeks back and I've started to strip the front suspension to see what's what before it gets driven. on the right hand side here's what I found under mounds of dried grease:
1) trunnion pins badly scored, not sure if I should keep the original trunnions and press in new pins or spring for new trunnions. I hear that new trunnions are hit of miss, so at least I know the ones that were on there fit. with the trunnion screwed into the upright there is a bit of side-to-side play, not much up and down, but I don't really know how much play is ok.
2) one of the inner lower wishbone steel bushes is seized to the chassis; I may try to heat it up and use a vice-grip to see if I can free it, but that will definitely ruin it. Any tips welcome.
3) upper ball joint is really notchy so that will get replaced.
4) upper inner wishbone bushes seem to be nylatrons as used in the lower inner wishbones... except that the metal inner bushes are stuck solid inside the outer nylatron bush, so the wishbones pivot around the fulcrum pins on the inner steel bush, not on the nylatron. Anyone know for this setup, shouldn't the steel bush be clamped tight so that the wishbone pivots on the nylatron bush, rather than between the steel bush and the fulcrum pin itself? Needless to say the fulcrum pins are bone dry, rusty and pitted, so to be replaced.
5) the spring spacer was mounted under the spring instead of top of it as shown in the drawings. When I inspected the spacer, I found some eccentric wear on the inside of the spacer. The top of the spax damper also has some wear on one side, so I suspect someone swapped the spacer to the bottom to avoid interference with the damper. I'm thinking of replacing spring with a standard longer spring 11" spring and not using the spacer, even if the original spring length seems nominal.
that's it so far, building a shopping list which is looking extensive - bushes all round, trunnions, springs, ball joints and other bits and bobs.
