jvandyke
I already swapped the Weber back on. At one point I checked for clearance there and had it, but just now I looked close and it seems it could have been hanging up there again, which would certainly explain why the idle wouldn't come back down! Now I'm tempting to put them back on!
I couldn't get low idle even with the throttle linkage loose though so I don't know if I can blame that entirely. Thanks for pointing that out though, I need to watch that I not only set that clearance but MAINTAIN it after continued mess'n.
Should I expect to be able to eliminate all daylight around the throttle disks?
I'm really interested to know what happens when the throttle screws are fully backed out under normal circumstances. I'd guess it would stall if the disks are sealing well?
