jet_jockey
Hello All,
I am a new XKE Series ll owner. I have found the throttle linkage on the inner manifold sticks after shutting the engine down for several hours. I suspect temperature changes to the metal aound the butterfly valves. Could this be the culprit? Is there a fix absent removing this inner manifold?
Currently I simply block the throttle open upon shutdown. It is OK for short shutdowns but once things cool off it binds up again.
Greg in Montana
Greg in Montana
