Source for Bugeye top - rear bar
drooartz
Anyone have a source for the rear retainer bar for a Bugeye top? Mine just has two small pieces of metal, but I know it should have the one long bar.
AHSpares lists one.
drooartz
drooartz
Thanks, Trevor. Hadn't checked them.
Whitephrog
I have a spare front or rear. Not sure which. I check later today.
RickB
Pretty sure I have a spare rear bar, my AMCO top didn't use the full bar, just the two shorties.
As opposed to the front bar which should be straight the back is curved a little IIRC.
drooartz
drooartz
Thanks, guys. Let me know if you do run across one. I'm interested.
RickB
If you PM me your mailing address I'll send you the one I have.
If you want to pay for postage that's fine, I will have to figure out how to send it so they don't bend it.
drooartz
drooartz
PM sent Rick. Just need a long skinny box.
bugedd
You can just get someone to trace one, send you the drawing, and have a local metal shop cut it for you out of aluminum. Worked perfect for me.
RickB
I will trace mine before I send it to Drew.
Anyone who wants the template just let me know.
Gerard
There are Priority Mail tubes (triangular) that would fit and the boxes are free. A poster mailing tube would work too, depending on the curve and length.
mrsprite
FWIW.....I just bought one from Victoria British (part #9-9021....$16.95). It works much better than the stiff wire that my top had. :smile:
drooartz
drooartz
I really need to start checking all the catalogs... after all these years you'd think I'd have learned my lesson...
nomad
Not that hard to bend one from a cold rolled strap. Just need a stout vise and a little ingenuity.
Kurt.
I Source for Bugeye convertible top? Spridgets 6
W Best source for Bugeye front shocks Spridgets 3
TulsaFred Source for Bugeye dash/switch bezel nuts Spridgets 9
I Source for ribbed material for inside bugeye door? Spridgets 5
I Source for Bugeye tire pump parts? Spridgets 14
I Source for Bugeye accelerator return spring? Spridgets 2
I Bugeye handbrake spring source? Spridgets 1
I Source for broken Bugeye heater cable/switches? Spridgets 2
I Source for Bugeye steering rack shim? Spridgets 5
I Source for bugeye exhaust bracket? Spridgets 4
I Source for 1960 Bugeye wire harness? Spridgets 11
I Source for new Bugeye kingpins? Spridgets 9
I source for original steering gaters for Bugeye? Spridgets 4
I Source for good Bugeye parts? Spridgets 8
D Best US or UK source/value on Bugeye seat covers? Austin Healey 0
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
