OK, first thing I need to get is a lathe!kodanja said:<span style="font-weight: bold"> Check this out' </span>
Brosky said:Well Dale, look at it this way. If you only clean up the crap and put it back together, it will be better than before, at the cost of some of your labor, parts cleaner and a valve cover gasket.
Try that and see how it is after cleaning the shaft out. Lube it well with oil and reassemble. It can't hurt and it will be running again.
TR6oldtimer said:OK, first thing I need to get is a lathe!kodanja said:<span style="font-weight: bold"> Check this out' </span>The rocker arm wear where the arm hits the valve stem is often over looked by the backyard mechanic. With labor prices as they are in my area, it is less expensive to buy new, the refurb. A great video.![]()
Brosky said:But Dale, are you getting new plugs with the new shaft? Did they confirm that they were already in it, or did you order news ones to go with it?
I just called and spoke to Blaine at that number, he assured me that they are still in business. Unfortunately I didn't think to ask about pricing for a TR6, so someone else will have to do that.tdskip said:Rocker Arm Specialist
19841 Hirsch Ct
Anderson, CA 96007-4910
(530) 378-1075
Anyone have a ballpark from them vs TRF for the rebuild?
I only watched a few seconds, but it's interesting that his device does not hold a constant radius on the tip. It's left to the skill of the machinist; which is certainly a valid technique with a good machinist. But I'm not that good with freehand work, can't even grind a decent drill bit.kodanja said:<span style="font-weight: bold"> Check this out' </span>
Just a thought, Dale. I've not tried this on a TR6 rocker shaft, but the plugs that retain the shift detents in the gearbox top cover appear to be similar. I found that I could remove them easily using a bottoming tap of suitable diameter (so the tap would cut into the inside walls of the cup), a short spacer (or a stack of flat washers would do) and a nut. Load the nut & spacer onto the tap, then turn the tap into the cup until the cup turns, and turn the nut down to extract the cup.Tinster said:From what I can tell, they
are expansion plugs and driven into place. It appears (on mine) they
must be drilled out.
