Richmond VA 1960 Bugeye Bringing Miss Eva back to life.
Agreed with your comment! I think he has created diversity to the market and the buyers, just depends on what they want. Details in my view makes a huge difference to the overall performance and character of the car.
This was a mystery patch. I knew it was for an antenna. Not sure if this was the factory location.
I would almost promise the patch was done at the factory. The metal is so thin, the spot welds were so small and precise. It would take a factory craftsman for the skill to do this. I cannot imagine why they would have done it unless it was a mistake of some kind. The metal under the patch was bare metal that had never been primed. I wonder if anyone has seen this before.
That hole was for radio antenna. Got the same thing on Bugsy IV.
However, it is my understanding that radios were never a factory option - only a dealer installed option. Thus there never was a "standard" antenna location - it was wherever the dealer decided it would be.
I too had the dealer installed antenna which I didn't want. I made a round plug and flush mount welded in place. I also lead filled that area prier to epoxy priming. It's all in the details when your looking at the final outcome, your doing a great job on your car!!
Alan,
On the list of things to do on Bugsy when he gets to paint next fall. I like the way you did this one,. I had a similar idea on how to fix.
Speedhut Gauges we discussed are ordered.
Starting to work the "A" Posts on both sides. Even with a number of pictures I still have at least 3 shots that could have been taken of filler then sanding then another application. Still will have to be blocked when I have addressed the entire body. I know I should stay on one section until completely blocked but I have to move around to keep my interest up. Also it seems when I come back I tend to see it differently.
Missing several sanding sequences.
I started stripping the BE rear end. I tore it down and I hope I can use the parts car I have to rob the center section and I also plan to use the later model rear brakes and backer plates. Too cold today in Richmond for body work. Last night was about 18 and that is cold for our area.
This is my donor car. I am not sure of the year. I know the motor in it is a 1275.
I am not sure of the year. If anyone knows fill me in on it.
We need a VIN # and can tell you the year
Just found your post today. Thanks for sharing it. I have to construct a rotisserie for my MKIII project. Can you share the dimensions and save me some guess work? Thanks.
Just putting it out there, I made my rotisserie with 2X4's - cost me peanuts.
No real measurements. Wood or angle iron between rear light holes and someway to catch the front end. Mine is simple and I am sure there are better designed ways.
No vin that I can find. I was guessing with chrome bumpers and square wheel arches and a 1275 that would narrow down the year. Also side markers might be a clue.
Materials Needed
6' 2 x 6 - 5' or so goes across the rear of the car and 3 pieces of 2 x 8 or 2 x 10 go across the 3/4" Plywood bolted to the radiator support bracket. They need to be through bolted together -
2 x 4' Piece of 3/4" Plywood cut to fit between Radiator Uprights - measure a 2 x 2 might be enough. Fit tightly and I drilled out to get next larger sized bolt in there. Tight fit help s to ensure strength.
Threaded Rod 7/16", Large Washers, Nuts, Bolts, Use threaded rod to go through the rotating piece on engine stand.
Bolts to fit radiator support openings
1 12' 2 x 4 for Center Support, OPtional 1 8' 2 x 4 for bolting larger wheels to engine stands
3 10' pieces of conduit, plus 2 conduit Couplers, Coupler holes need to be drilled so screws on coupler can go through conduit to eliminate a friction fit.
I added larger wheels, 2 that swivel with locks and one pair that did not swivel 6" wheels if within the budget. Purchased Large U Bolts that fit the bolt holes of the Wheels. Mounted through a piece of 2 x 4 with nuts on the bottom. Top of U Bolt goes over the top of the Engine Stand Outrigger. This serves two important purposes 1) bigger wheels make it easier to move around and locks help to keep it in place. 2) the piece of 2 x 4 bolted to the bottom of the engine stand along with wheels give you and additional 4-5" of ground clearance. Enough to allow you full 360 degree rotation. Tractor Supply and Harbor Freight provided Wheels. Swiveling Wheels w Locks came from Tractor Supply.
Bolts go through tail lamps opening. If I was to do again I would consider a L shaped bracket that used the bumper mounting holes in the trunk. Since I was going to need access to do repair back there I choose the tail lamps. Use large Rubber washers and a piece of wood back there inside the trunk as backing plate for the 2 x 6" Board.
To lift the body on to the rotisserie, I used 2 large Eye Bolts screwed into each end of the 2 x 6 along with a piece of rope that led to a chain hoist in the rafters of my garage. To lift the front, find 4 buddies, I recruited the crew of Grandsons who had just eaten Thanksgiving Dinner to pick up the front of Bugsy. Other wise an Engine Crane will do.
It is important that you be ready to attach the center 12' 2 x 4 to tie both ends of the rotisserie together. In my case I again used a long U Bolt to bolt the 2 x 4 as low as possible to the underneath side of the rotisserie, the two pieces of electrical conduit are used to square up rotisserie on both ends. Oh and the most important part. The Center Wheel of the Engine Stand is not used. If you look at the engine stand it is not level, designed that way so it can flex when you put a 500lb engine on it. Removing the center wheel allow the rotating piece of the engine stand to be at 90 degrees from the floor.
So without the center 2 x 4" Brace in place the rotisserie will look like this /----\ when you remove the overhead hoisting ropes. That can also do damage to the body. You want the center brace in place ASAP even before you lower the car off of the hoisting ropes. As a Result your rotisserie will look like |-----| this.
Additional questions 937-654-6388 is my cell.
Took some parts in to the blaster. He turned it around in 24 hours.
One perfect door out of two.
I had warned him about warping the flat panels on the doors. When he saw some bondo he backed off and just did a surface removal.
It ended up having a minor dent and rust in the bottom corner. Very easy fix.
