Isn't it strange how I manage to come up with these off the wall problems.
Latest in this series.
Low oil pressure, pull the engine and install a new pump. Also change out the clutch set for all new.
Still no oil pressure and the clutch set was wrong.
Pull the engine, new bearings, rehone cylinders, new different clutch set.
Oil pressure great. Clutch fine but needs longer rod. Engine leaks like a sive at the rear end.
Pull engine, redo tranny rear seal.
Still leakes like a sive.
Pull engine and redo the scroll seal.
Leaks but now from rear of oil pan.
Pull pan and reseal.
Stoped that one.
Still leaks from the rear seal. Not sure I would call it a leak or blow by. Plugs for #s 1, 2,and 4 look like they are seating. #3 is black and oily. Only about 10 miles so far on engine.
So of course a long run is in order tomorrow.
Also ordered from MM a bottom end ventilation thing for the fuel pump hole hopefully to take what pressure there is off of the rear seal. Might not need it if rings seat OK. Who knows.
It has been quite a ride guys and I surely appreciate your holding my hand.
