Mychael
Well I gotr the quote back from the place that odes both PC and conventional painting. To have my chassis blasted, primed with a zinc rich PC then a top coat PC would set me back about $2,000. Whew.
I cannot get the SEM paints here, at least not the corrosion proofing type. I've found something called Tectyl 506 but the problem with that is it states for optimum effect it must be applied over a clean, dry, rust and dust free surface which is impossible to achieve the box sections of the chassis, so again it comes back to Fish Oil or cavity wax.
I'm now getting some quotes for EPRS systems which use low voltage to produce a sacrificial charge through the body, very widely used in the marine and four wheel driving industries.
Mike
Mike
