with everyone... prep, prep, prep.dklawson said:...POR will come off in sheets... if applied to sound metal. There is no "tooth" on a smooth surface to help POR adhere... ....The name "POR" supposedly stands for Paint-Over-Rust. My experience has been that you need to get all but flash rust off the surface if you want success... Whenever I have painted over rust (after acid treating), if the rust was heavy it blisters through again....
PeterK said:Probably by far the best rust fix I've ued is the MIG.
luke44 said:dklawson said:..
- I went the powder coating direction on mine - it's really not all that much more expensive than properly prepped frame for a coating of any brand...and the results are significantly better. My Cobra Replica also was powder coated. Once you have used powder coating, nothing else measures up.
Apologies for taking this thread in another direction but I'm following it closely as I am working on my chassis now.
I bought this chassis restored and powdercoated ( I should say at this point I have no fixed opinions one way or another), asking around there seems to be two opposing camps for and against powdercoating, those for it will point out it's durability, resistence to salts and chemicals etc, those against it will warn that rust can run underneath it and you'll never know till it's too late, they say it's fine on rigid structures but on the (sidescreen TR chassis) there is too much flexing and the powdercoat can get micro cracks and allow moisture in.
I honestly don't know, we can get POR 15 here in Australia but not some of the other paints mentioned.
I'm debating now whether to sandblast and start over again or stay with the powdercoating, that fact I will be doing more welding anyway has me tending towards a full sandblast.
I may be wrong here but I was under the impression that POR was first developed for marine use which is a very harsh environment if that were the case then you'd think it would be easy for it to protect a chassis.
What I will be doing is flushing the inside of the chassis with Fishoilene (possible known as waxoyl elsewhere), this I know from past use will coat over and seal rust but won't dry properly on previously painted surfaces or very smooth metal.
Mychael said:they say it's fine on rigid structures but on the (sidescreen TR chassis) there is too much flexing and the powdercoat can get micro cracks and allow moisture in.
Hillbilly said:I have not messed with PC. But what little I do know of this stuff, I think your part needs to be baked after the application of the finish material.....correct?
Well this leaves me out. I know the Triumph Chasss are small, but not QUITE small enough to fit in my oven.
Hillbilly said:I think your part needs to be baked after the application of the finish material.....correct?
LexTR3 said:Seems to me we are divided roughly into two camps (and not necessarily on the product to use). The camps are those who are doing a large-scale "professional" (full or nearly full) restoration and those who are just fighting the good fight against rust. What works for one group (shop with proper equipment and adequate ventilation) will not work for the other group (home garage shop and nothing but a fan for ventilation). This thread has good information and advice each camp, but there may not be complete crossover with some of these very specialized and strong products (i.e., breath the fumes and they will nearly knock you out).
