pa297pass
Hi all! Happy New Year!
I am thinking of partially replacing the driver's floorpan on my TR6. It has many rust pinholes in the front portion of it. I want to install carpet in my car, but refuse to spend that money without fixing the floor first.
Anyway, here is what I am thinking of doing, and I want your opinions. The inner and outer sills are good (as far as I know) as well as the "channel" where the tunnel cover bolts. I want to cut out the flat portion of the floorpan, from in front of the seat to somewhere under the dash. I would leave maybe a 1/2" lip along the outer (sill) and the inner (trans cover channel) sides. I then would cut my new floorpan larger (1/2") than the hole in my floor, lay it on top of the floor, and spot or seam weld it in place. I would then seal it on the top and as best I could on the bottom with automotive seam sealer.
I know this is far from concours, or even correct, but what are your thoughts? While I would someday like to do a frame up restoration on this car, I can not allow myself to take it off the road at this time.
TR6BILL - do you have any advice? I saw in the archives you recently tackled a similar rust hole problem. I was wondering how you handled it.
Thank you all for your help.
Matt
Matt
