I can verify that, indeed, according to Jim Knight of British Racing Green, only the last few thousand cars had a 3.73 differential. Also, apparently all axles are interchangeable. I had some confusion about that, but don't know where I got the idea that they weren't the same. As of yet, I have not been able to get to the bottom of the problem, but I suspect it's an axle shaft or spider gears. I'll update as soon as I know. However, if the ring and pinion need to be replaced, how does one go about rebuilding the differential? It would seem to me that the backlash would need to be set with shims, but I wonder what the specification is. I also wonder if there are any other settings that are critical. Can anyone speak to this? Thanks!
Also, an update from what I've read on the Grassroots Motorsports page concerning the Phantom Grip differential. It would seem that it is essentially the stock differential spider gears and carrier, with a spring loaded metal block that presses against the spider gears to slightly prevent rotation. However, the resistance is not all that great (depends on spring rate), puts large additional loads in unintended directions on the spider gears and shaft, generates metal swarf that can be very bad for bearings etc as the block and gears wear down, and finally, once the wheels start spinning at a different speed, they're inclined to spin almost as with an open differential due to 'stick-slip' friction where static is greater than kinetic friction (the whole reason behind ABS). Therefore, it will not appreciably help power you out of corners like a genuine LSD, regardless of design (other than this one). A welded diff is definitely harder to drive on the street, but at speed, it would likely provide considerably better performance than an open or phantom grip setup. Basically, it would seem that it isn't worth it unless you like rebuilding your differential. As an aside, I don't personally own one of these units, so I only can go by what other people have said and by the diagrams on their website. I am only drawing conclusions based on hearsay, not the actual design. However, these conclusions are negative. It would be great if this unit worked, as it's quite cheap. Unfortunately it does not appear to do what they claim very well. Also, there are reports of exploding differentials as a result of this item, which is logical as you are stressing the already comparatively weak spider gears of the differential even more. Ask Mark (SilentUnicorn) about what happens when you drop the clutch at high RPM ... the gears will self destruct. This unit will probably induce failure even more easily, so I'm not inclined to try it. Hope this helps for future reference.
Matt
