Hi all;
I've gone down the LED rabbit hole on my 1976 TR6. I intend to install 2 indicator lights for the turn signal in the dash. I'm looking for wiring ideas. It should be pretty simple, but it's been a while since I've worked in DC circuits. Planning to change both the hazard and turn signal flashers, and convert all exterior bulbs to LED.
2 for one: I note that the existing instrument bulbs are T7 wedge, which is almost unknown. I have a table showing dimensions for capless/wedge bulbs, and the ones I have measure exactly to the T7. I know that with a replaced harness, which this may be, normally the bulbs are T10. The measurements for these are just not T10. Is there another bulb I can use in these T7 bases? I'll post the table of bulb
Thanks in advance.
Michael
Thanks in advance.
Michael
Hi Guest!
