TR2/3/3A Latest Tires
CJD
Chassis time is finally here, so I need a set of tires. Number one priority is that I would like the tire to fit the TR2 spare well without too much trouble (48 spoke wire wheels). Performance is not a concern, although quality is. Tires I am looking at currently are:
Michelin XZX, which is a 165 wide tire, and appears to be the only one they make for us.
Pirelli 155HR15 Cinturato CA67, which is a bit narrower tire.
I just wondered if anyone has experience with these...or if there are other recommendations for a tire that will fit the well?
Geo Hahn
I have always had to deflate my 165s to get them into the spare well on my pre-60000 TR3A. That's with a steel rim and all brands I have used through the years (Michelin, Nexen, Cooper, Kuhmo & Vreds).
Not that big a deal if you also carry a compressor or (better yet) never have a flat.
In any case, not all spare compartments are the same after all these years and replacement of panels just adds to that so it may be difficult to take someone else's experience 'to the bank'.
TomMull
I bought a set of Michelin X tires quite a few years ago simply because they had the same tread pattern that was on the car when I bought it in 1964. I don't think those are available in 155 or 165 15 any more. I guess the xzx would be a good substitute (I have them on the Herald with no issues.) as would the Pirellis. I have no experience with others.
My post 60k TR3 accepts the steel wheeled spare in the tire cubby, fully inflated. My earlier car has a spare in it but I don't think I've ever checked the size, nor the pressure for that matter. On my to do list now.
Tom
sp53
Just a rumor, but I heard that all the tires that fit these cars are made at the same place. The story goes they bought all the molds. If true and for my way of thinking, I would expect all the tires to cost about the same.
PatGalvin
Hi John
I went into Discount Tire and they calc'd the diameter of my four main tires and then identified a thinner spare with the same diameter but flatter profile so it slips right in, fully inflated, into the spare well (with steel wheel). I can check all the numbers tonight and let you know what I've got, in case it's important. If you want five tires that are all identical, then my info won't be much help.
pat
trglory
I seem to remember someone using a compact spare from a mid 90s Japanese car. They claimed that it had the right bolt pattern and rolling radius and it fit in the tire compartment with plenty of room to spare. The advantage here would be that if you had this as a spare you could use whatever sized tire on the car that you preferred. Obviously, if you had the spare mounted on the car you would need to temporarily carry the oversized flat tire behind the seats. Does anyone have a better memory than me to recall the specifics?
mgedit
Here is the combo I used ... stock steel rim with narrower tire for spare. Kumhos mounted on alloy rims. Cheers, Mike
CJD
CJD
Thanks for the responses! I have to be honest, I hadn't even thought about having a narrow tire for the spare...Duh! It sounds like that is the way to go. Having the spare in the tire rotation only complicates rotation anyway. From the ideas above, I also found the Kumho's are very reasonably priced. I'm pretty sure those are what were on my TR3 when I got it. I also see Discount sells a "Classic" brand tire for about $60.
Thanks again for all the input to help me make a choice!
CJD
CJD
Update: Started calling around. The Kumho's are out of stock everywhere I found. The Michelins at Coker are $126 ea for the tires, but when I filled out the address, they run another $105 ea for shipping. Gulp! I refuse to pay as much for shipping as the tire costs.
Moving on...
CJD
CJD
That's what I am seeing. I initially thought it WAS a Michelin, but I now realize they simply bought the old Michelin mold and reproduce the tire.
Oh...the shipping must have had a glitch...after telling me it would be over $400 to ship a set, the browser popped back to $105 to ship all 5. Much more reasonable!?!
mallard
If Coker sells them try Jegs or Speedway. They will ship them for free after $250.00 total That's how I got my Vredestein's. Which buy the way fit in with ease into the spare tire slot.
Lou Metelko
Hi John:
All five tires on my TR2 (TS981L) are Vredesteins and the 4" steel wheel spare just does barely fit with the 155R15. Don't know if your 48 spoke wires would be different but in my case it is a tight fit! Bought from Coker (good service, reliable products and decent price).
Lou Metelko
Auburn, Indiana
2long
I am running Firestone F560, in the original width of 155 for my TR2 with 48 spoke wires. I like something closer to the original grip and release point. It fits in my spare compartment.
Dan
CJD
CJD
Boy I hate picking tires...I do really appreciate the comments and tips. I have spent the last several hours researching all of your choices and tips above.
The cheapest tire we currently have available for our TR2/3's is by Nankang. About $57 and free shipping from Amazon. I could not bring myself to buy a Chinese tire. Just me...as the reviews were actually good for it.
I then checked out the Kumhos, but they all seem to be out of stock. They may have abandoned us!?!
I like the Vredestiens, but their price was approaching that of the vintage reproduction tires.
I almost popped on the Firestones, as they are the least expensive of the vintage, at about $80 each. The most expensive tires are the Pirelli's, at over $200 ea. I couldn't justify that price.
I finally went for the Michelins. The write up made it sound like they are reproductions of the original 1940's/50's tire, that could have actually been installed on the TR2 "back in the day". I checked out Jeg's and Speedway...free shipping, but they upped the price a bit. The interesting thing is that the more I clicked around on the Coker website, the cheaper the shipping got!?! It wound up bottoming at $35 for 5 tires and tubes. In the end the cheapest price delivered to my door was from the Coker direct...assuming they don't call tomorrow and say the shipping was a mistake.
Again, thanks to each and every one of you who responded. Even if I didn't go with your recommendation, I used it to arrive at my final choice!
Edit: Oh, I went with the 165/80r15's all around, and the 145/80r15 for the spare. I'll report back later with the spare compartment fit...
mrv8q
So how do you guys get your shipped-to-you tires mounted on your wheels? I can't imagine any tire store around me mounting tires they didn't sell me without greatly overcharging.
Thinking further, how does Tire Rack do it? Is rhere a network of independent tire stores around? I guess I'm surrounded by chains and franchises, not that I've investigated too much...
Alfred E. Neuman
Lots of good independent auto repair shops have tire machines and some even have alignment racks (we have both). It's worth calling a couple and see if they'll cut you a deal on simple mount and balance.
Gliderman8
I am using a spacesaver spare from an Accura. Hole pattern is identical to my TR6. Now there is lots of room in the spare tire well and it saves the weight of a full size tire.
AngliaGT TR6 TR6 Tires - What's the latest information? Triumph 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
K TR2/3/3A The latest "It's always something." Triumph 8
vette Latest Moss Motors Magazine Austin Healey 1
drooartz The latest tool addition to the shop Restoration & Tools 25
C TR6 Latest TR6 updates and pics Triumph 10
Gliderman8 "Latest Resources" FORUM Navigation Questions 2
Boink Sir Paul's latest video... with Frogeye! Spridgets 6
Rut Latest fluid recommendations Spridgets 5
K TR2/3/3A Tyre question, and an Latest Triumph 9
PeterK General TR Nice TR6 on Griot's Garage latest catalog Triumph 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
D Lilly Engine Latest Austin Healey 14
D Lilly Engine Latest / couple of questions Austin Healey 34
Rhodyspit75 Bugeye restoration Latest Spridgets 16
Michael Oritt Randy Forbes Latest Austin Healey 11
69MGC Latest Jaguar Digital Illustration Jaguar 0
D Latest on Lilly Austin Healey 3
D Lilly Latest Austin Healey 1
G TR4/4A Latest and greatest for water pumps Triumph 18
T TR2/3/3A Alternator failure Latest Triumph 17
PC latest tool score Restoration & Tools 4
simon1966 BN1 restoration Latest Austin Healey 2
Boink Nice Bugeye spread in the latest issue... Spridgets 4
Keoke Latest Upgrade Austin Healey 3
davidb Latest - AH 3000 steering box lubrication Austin Healey 4
davidb Latest - upholstery glue Austin Healey 14
Rut Bugeye Latest Spridgets 10
C TR6 Just an Latest Triumph 1
Got_All_4 General TR What to do in a "a" type Latest Triumph 9
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
P TR6 Latest compression test Triumph 11
K 9 year Latest Austin Healey 5
Keith_M Bugeye bodywork Latest Spridgets 2
PC latest tool hunt Restoration & Tools 15
J TR2/3/3A 59 TR3A Latest Video #2 Triumph 3
Kirk_Fisher TR4/4A Flood restoration Latest Triumph 1
me61ic 1963 BJ7 Resto Latest Austin Healey 2
Boink Healey appears in latest JibJab year summary... Austin Healey 1
B Resto Latest Austin Healey 35
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
U Spitfire Questions About My Latest Spitifre Triumph 14
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
T TR2/3/3A latest with my H6Ss Triumph 22
Mickey Richaud Off Topic One of Our Own in Latest Moss Mag... Triumph 9
A clutch Latest Triumph 0
P valve job Latest Triumph 9
bcliff T-Series TF Victor Latest MG 11
F TR4/4A TR4 Downdraft install Latest... Triumph 0
F TR4/4A Clitty Clack Latest on my TR4.... Triumph 5
