I read some time ago that there may be a way of removing the glove box and making a "tool" to grab the latch mechanism to open the hood. Maybe someone else knows the particulars of this method and will chime in.
Hi Guest!
I just found this video. I hope it helps.My time has come :dejection: Looking for a method of unsticking the stuck if the normal and emergency hood releases no longer release. Anyone try coming up from underneath?
My e-type had mechanical locking rods on both sides as well as a central safety catch. Without either it would not open moving forward, but under braking or reverse, up she'd go.I have yet to see the reason to latch the hood anyway it does not lift at 100 MPH
Edit: Looks like the pictures arranged themselves in reverse order...
Gave it another try today with a suggestion received. The emergency one would not push in. The camera helped find it after quite a bit of time getting it into a position to see. Handy thing to have though. I figured just put more effort in the driver side release, but it released after heavily leaning back on it. The emergency one must have slipped past the release when the hood was closed. Thanks for the suggestions and comments![]()
Be careful with the emergency cable. Friend was looking with me at a TR6 in Florida and when I showed him the emergency cable, he pulled it hard and it went past the stop. Fortunately, no one was watching and I managed to wedge it back up into place. Make sure all parts are tight.
Funny you should mention this. I was looking at my emergency release mod on my TR6 the other week and I noticed that the lever mechanism had come so loose from its pivot bolt and would not have worked at all should I have needed it. So if you have this mod, be sure to check it out once in a while, LOL.
