vettedog72
I am in hopes some one will enlighten me and possible others about the rocker arm ratio when the ratio is increased from stock.
I am wondering about the change of the rocker arm length. I guess the valve side of the rocker shaft remains the same length as stock (so it will line up on the valve stem). So the push rod side must be shorten? If that side is shorten will there be any material effect of the change of the angle of the push rod at the lifter?
The 1.5 to 1 bolt on roller rocker kit sure seems to be a way of adding a few horses to the tractor but I have never seen a direct comparison.
