Re: Help! Weber 40DCOE throttle problems Update
OK just got off the phone with the weber tech, we went through everything. Everything I have on the carb in the way of jets and venturis is good, EXCEPT the disharge pump valve. I have bought a 50 discharge dump valve and it is SUPPOSE to be closed. I had a new one I ordered cause I wasn't sure what it had in it. So he told me that when I hit the throttle hard half of the fuel is bleeding back into the fuel bowl. He said there should be no hole allowing a full stream of fuel when the butterflys open. I suggested JB Weld to close the hole, he agreed but said to make sure that the JB Weld does not go in so far that it contacs the one way check ball. I have plugged the hole and the ball moves freely. I am letting it set for 24 hrs, then I will install it and see what happens. Shot down by a pin hole!
Keeping fingres crossed.
Ðan
The saga continues
