Excellent!.... Well, from this I've learned a lot about HD8's and that makes me a bit more comfortable with them. I've now advanced from tuning them to knowing what it takes to rebuild them.
Hi Guest!
Nock got me using richer needles a few years ago stating it help with ethanol fuel. I really haven't noticed any difference.
Then I installed the normal UH needles to try them for a while. What I noticed immediately is cruise shows good power 12s but when you give it the gas the car leans into the mid 13s. Both jet drops set at: .076"
What fluid are you using in the carb dashpots?
Got any straight 50 you can try just for yucks? Maybe some gear oil? Since you have A/F sensors I'm curious to see what effect it would have.
Stiffer springs?
My understanding is stiffer springs if they were available would have the effect of holding the needle down (lean) further in relation to throttle opening. Off idle the car would run richer due to less air per unit fuel. More open throttle the car would be a little leaner.
