TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it?
TR Mike
Has anyone tried to put sound deadening material (like Dynamat or similar material) in a TR3. I am at the point where I will be installing carpet soon and was considering putting sound deadening on the floor and in the trunk area. It is worth the effort and expense? My new carpet kit has a felt layer, but I am talking about the foil faced material that is self adhesive.
Administrator
Boss
Not in a TR3 but I put a similar product called "Roadkill" in the cockpit of my EType. The stuff is amazing!
Gordon_Dedrick
I used two types, a heat reflective one on the transmission tunnel, and regular sound deadening on the floors and inside the doors. Made a HUGE difference in both road noise and heat inside the cockpit.
M
Member 10617
TR Mike,
I put foil covered felt, heat and sound deading material from Moss in my TR3. It has provided great heat protection and sound deadening. I found it very affordable and very easy to install.
M
Member 10617
Bill,
I used what Moss lables as "Heatshield Material." You can find it on page A8 in their catalog.
I did not glue it down. Instead, I used 2" wide strips of VELCRO to hold it down. That way, whenever I want to remove the carpeting and the heatshield material to inspect, I can just pull it up and put it back down. Works fine.
Jerry
I put the Dynamat in my Healey and it was really good at sound reduction, not as good at heat reduction which was what I was trying to do.
Jerry
M
Member 10617
The "Heatshield Material" I installed is very thick and for that reason, I guess, has been excellent for heat reduction.
poolboy
It's good stuff. I had it in my 74 TR6. Beside it's advertised attributes, it makes for a nice thick carpet underlayment.
Lbp
LexTR3:
How many sheets of the heatshield material did you need to do the whole car? And did you use it instead of the felt undercarpet material, or in addition to the standard felt?
Bill
M
Member 10617
Bill,
As I recall, I only ordered one 4' x 6' sheet, and -- with very careful measuring and cutting -- I only had a few very small scraps left over. I only did the area in front of the seats, and not the "back seat" area. (Foil side down.) This is the only thing I used because the felt part of the heatshield is quite thick. I laid the carpet right on top of it. I don't think you would need an additional undercarpet material.
And, again, I didn't use the adhesive Moss sells with this material because I didn't want to glue this stuff down. That is what was done previously and I had a heck of a job getting up all the old adhesive in order to repaint, etc., etc. I used 1" wide Velcro in strategic areas to hold the material down (foil side down).
One other tip... When I installed the heatshield material up the sides of the cockpit area, I cut it about 2 inches shorter than where the carpet would rise. This left me 2 inches for velcro on the side panel and on the carpet to hold it in place. In other words, the heatshield material is velcroed into place on the sides, right and left, and in front, and the carpets are also velcroed right and left, and in front, but to the wall just above the heatshield and not to the heatshield material itself. (Sorry for this poor description). The result is that I can remove the carpet for cleaning, etc., etc., without disturbing the heatshield material, and I can remove the heatshield material for inspection, repainting, etc., etc. My aim was: don't do anything that cannot be easily undone.
Sorry, too, for being so wordy... Hope this helps.
Bill: Check my following posting for a couple of photos I just took for you.
M
Member 10617
Bill:
The photo on the left shows the carpet in place. The photo on the right shows the carpet pulled back to show the Velcro strip that holds it, and you can see the heatshield (also held in place with Velcro). You can also see the remnants on the back of the carpet of the adhesive that once used to hold it in place. The previous owner didn't use any underlayer -- just carpet and rubber mat.
The Velcro adheres very well to the foil backing of the heatshield, but not so well to the back of the carpet because the back of the carpet is rubberized and heavily textured. For that reason, I had to stick the Velcro to the carpet using two-sided auto trim tape, and in some areas some liquid adhesive.
View attachment 25874View attachment 25875
TR3driver
Great Pumpkin - R.I.P
Bill,
FWIW, I got what appears to be the same stuff from Home Depot as "water heater insulation". About half the price once you factor in shipping and I installed it the same day. Only on the floors and trans tunnel as yet, but I'm pleased with the result. Otherwise on long summer trips, the trans tunnel would get too hot to comfortably rest my leg against.
But I was primarily interested in heat insulation. My feeling is that, unless you have a hardtop, most of the noise comes directly to your ears from outside the car; relatively little comes through the metal. And I hate driving with the hardtop anyway (haven't had it on the car since 1989 and then it was only to move it) so I'm not worried about that.
Lbp
Ed/LexTR3:
The pics you attached don't show up. I don't now if it's the site or my computer, but I think I understand your description. Thanks for taking the time to help me out. I was also reluctant to glue everything down and got a set of snaps, but velcro sounds even easier.
Bill
TR4nut
Ed -
If you can try again sometime, I'd like to see those pictures too. I'm getting close to doing the same thing on my project 3A.
Thanks
Randy
NutmegCT
I keep reading about folks putting Dynamat in their cars as a heat shield. Dynamat is advertised as sound deadening. What am I missing?
(and ditto on the missing pictures)
Thanks.
Tom
PS - with my open top TR3A, I never feel the need to cut down on "sound". I did the same thing as Randall for heat shielding, and am very pleased with the result. No more toasted right leg.
M
Member 10617
Trying again... I hope these photos can be seen.
Randall: YES, indeed, the heatshield material looks a lot like the material for wrapping hot water heaters. And I agree with you about noise dampening. This stuff is primarily useful for cutting down on heat. But there is a little noise reduction, nevertheless.
Looking back on the project, I may have used more Velcro than really needed. Rather than continuous long strips, I might have simply used small squares stratigically placed. But either way, it seems to work.
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
steveg Has anyone used a knock sensor? Austin Healey 0
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
G TR4/4A Anyone know if this car has sold yet? Triumph 0
Sherlock Spokane Race Track, has anyone been there? Racing 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
G Has anyone here had any dealings with ANGLO PARTS.COM ? Austin Healey 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
MY66AH Has anyone used this paint?? Spridgets 7
H Has anyone changed their electrical distribution? Austin Healey 7
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
60TR3A Has Anyone Undercoated Their Car? Triumph 27
scoutll Has anyone had a hardtop shipped? Spridgets 15
S Has anyone ever seen or heard of this? Austin Healey 9
T Advice, has anyone done this Triumph 2
jlaird Has anyone noticed Spridgets 20
NardisCNC Has anyone used the Oberg Engine Tilt Lift?? Spridgets 15
Cookie Has anyone changed wheel cylinders? Spridgets 20
bgbassplyr Has anyone else Other British Cars 9
L Has anyone ever had to.... Spridgets 12
gubba Has anyone here used this Rack & Pinion? Triumph 8
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
T TR6 Has anyone ever made a new TR6? Triumph 20
angelfj1 Octane Boosters - Has Anyone Mixed their Own? Restoration & Tools 5
S Has anyone seen....... British Motor Corp 1
weewillie has anyone Restoration & Tools 12
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
regularman Has anyone ever done any wind tunnel tests.. Spridgets 22
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
C Has anyone seen........ Triumph 6
healeyboz Has anyone.... Spridgets 5
MGBGT_noob MGB Has anyone ever tried this with an MGB? MG 10
jlaird Has anyone Spridgets 4
H Anyone Own or Has Driven a TVR Sagaris? TVR 11
mgblue79 Has anyone tried E85? Spridgets 16
AweMan Has anyone ever .............. Triumph 10
roofman Has anyone installed an electronic voltage ... Triumph 19
W Home-made tonneau - has anyone tried? Triumph 15
Nunyas has anyone else seen this? MG 14
J Has anyone converted to TBI? Triumph 11
neilh Has anyone successfully patched a leaking tank? Spridgets 15
1 Has anyone ever heard this tip? "Weeping" head MG 11
bugimike Has anyone seen this on ebay? Spridgets 10
