Half way?
So I'm pretty sure I am at least half way done painting. The in/undersides of everything is done, except the hood and trunk lid, but the fenders are done inside and out. Spraying clear coat is not going as smoothly as hoped, pun intended. Everything looks fine, but the orange peel is terrible. I will either be sanding or buffing or sanding and re-spraying clear. The odd thing is, I try to do exactly the same thing each time, but the results are very different. -But it is coming along.
You may have already found this info...
This time of year high outside temperature is always a problem. You can buy high temp thinner which helps slow the dry time, but in any case best not to spray with the temp over about 90 degrees or in direct sunlight. I spray first thing in the morning. Also, spray more paint on each pass, I.e. thicker coats so there is more to flow together. Runs are much less of a problem in high temp.
Orange Peel
Also known as: poor flow, poor levelling, pebbling
Description
Uneven surface formation - much like that of the skin of an orange - which results from poor coalescence of atomized paint droplets. Paint droplets dry*before they can flow out and level smoothly together.
Origin and Potential Causes:
Improper gun adjustment and techniques. Too little air pressure, wide fan patterns or spraying at excessive gun distances causes droplets to become too dry during their travel time to the work surface and they remain as formed by gun nozzle.
Extreme shop temperature. When air temperature is too high, droplets lose more solvent and dry out before they can flow and level properly.
Improper dry. Gun fanning before paint droplets have a chance to flow together will cause orange peel.
Improper flash or recoat time between coats. If first coats of enamel are allowed to become too dry, solvent in the paint droplets of following coats will be absorbed into the first coat before proper flow is achieved.
Wrong thinner or reducer. Under-diluted paint or paint thinned with fast evaporating thinners or reducers causes the atomized droplets to become too dry before reaching the surface. Too high viscosity.
Low shop temperature.
Too little thinner or reducer.
Materials not uniformly mixed. Many finishes are formulated with components that aid coalescence. If these are not properly mixed, orange peel will result.
Substrate not sanded thoroughly*
Prevention Techniques:
Use proper gun adjustments, techniques, and air pressure.
Schedule painting to avoid temperature and humidity extremes.
Select the thinner or reducer that is suitable for existing conditions. The use of a slower evaporating thinner or reducer will overcome this.
Allow sufficient flash and dry time. Do not dry by fanning.
Allow proper drying time for undercoats and topcoats. Not too long or not too short.
Reduce to recommended viscosity with proper thinner/reducer.
Stir all pigmented undercoats and topcoats thoroughly.
Prepare and sand substrate correctly.
Follow recommendations on technical data sheets.
Remedy
For mild cases, sand and polish using recommended materials and techniques.
In extreme cases, sand down to smooth surface and refinish, using a slower evaporating thinner or reducer at the correct air pressure.
Yes, I have been waiting for both temperatures and humidy to drop so I can do some priming. Today was a good day and I managed to get the doors and the front valance done. Tomorrow looks good so will most likely be priming the boot and bonnet. Cheers, Tush
We were graced with some rain last night and a cooler than normal moist morning today. I was prepared to clear coat and got to see it flow like it's supposed to. A couple runs, but it looks great compared to the orange peel on the fenders. Ultra fine sanding on 2 of the fenders has required more color be applied, so I might just save the time and re-coat the clear on the remaining fenders. Still, for an inexperienced DIYer, I am very happy with all the results so far.
I am half way to putting it back together.
Very nice Jerry, very nice! Did you play with the buffer yet?
Nope. No buffing yet. I keep sanding thru the color and have to do do-overs... I'm sure there's an end in sight, but I can't see it just yet. Not even after I cleaned all the specs of clear coat off my glasses. That stuff gets everywhere.
Looking great Jerry.
I just read through this entire thread. TexasKnuckleHead, I say this with all due respect. You must be insane. What you have done is crazy, as in crazy good. Amazing work. I have a 1959 TR3 driver car. It's in OK shape, and I WAS considering, sometime, maybe to do such a restoration. Seeing this, and what you have had to do, I may stick to my trickle restoration. Wow. When you are done, this restoration will be one of the best. I bow in your presence. :cower:
I prefer to think of all the color/clear coats I have had to sand and respray as just really high class primer coats. Otherwise I would cry when I think of the cost of good paint...
Not many can say they did it all, you can, congratulations. We all sub out some of the work, but the painting is one of the hardest things, except for maybe color sanding and polishing. Great work
Thanks John. I was starting to think I was the only one. Each time my neighbor stops over and helps me see my mistakes, I feel like crawling under a rock. Sometimes it seems to get worse no matter how I try to fix it. Example: left fender clear didn't lay right, so I try to fine sand (#1000) it smooth, 99% finished when I go thru to primer, so I sand (#400) and re-spray color on that one spot, the color lifts and needs sanded (#400) and sprayed again, two coats of clear later on the whole fender looks ok except for one big run on the corner, carefully sand off the run in the clear(#1500), fine sand (#2000) the whole fender and find the color where I resprayed is different -about the size of a dime is much darker yellow, buff the fender to see too many 'fish eyes', so I sand (#400) it all away, sand (#240) the dime spot, re-seal the spot with epoxy primer and sand (#400)... tomorrow I'll re-spray the whole fender yellow (again) and get ready to spray clear the next day. -The other panels are cooperating as well but each are in different stages. One situation makes me chuckle; the rear apron is awaiting another coat of color because after I finished the other 4 panels I was working on (2 coats 10 minutes apart), I couldn't remember if I had or hadn't put the second coat on the rear apron, but I finished the paint I had mixed up and cleand the gun. Just in case I didn't do the second coat, I chose not to clear it until I did.
Mtn10flyer: "When you are done, this restoration will be one of the best." Thank you, it will be the best I have ever done, but there are better. Few have chosen such a disaster to start with, but we are all challenged differently.
Saturday, on the trunk and hood, I put 3 coats of color followed by 4 coats of clear -more than recommend by PPG, but I need enough clear to sand off the orange-peel. Sunday I spent wet sanding those two panels. Monday I buffed and polished them. Today I polished the tub with the fenders installed with all the bolts finger tight.
I wanted to see the 'finished' result actually in the sun so I pushed it out into the driveway. I think I'm more than half way out of the garage...
Looks beautiful Jer. You must be very excited to be nearly done with the very difficult Body and Paint step. You've about caught up with me!
Pat
Congratulations, you turned the corner. There is no end to the satisfaction you get when you go from picture 1 to picture 4.
Joe
Awesome. Hope mine turns out as well! Cheers Tush
Quick question...
What did you paint in? Home made paint booth? Did you get a lot of dust in the base and clear coats?
Looks great in the pictures!
A TR3 don't need no stinkin' paint booth.
I painted it in my garage with the doors open and a large exhaust fan pushing air out from the back side of the garage through a soffit vent. I would generally stand some old closet doors across the front to try to stop leaves and stuff from blowing in while I was painting. I painted small sections at a time when possible. In this picture you can see the hood and trunk in my "paint booth" -the last of the body parts to be painted.
Dust? Well, a few cat hairs fell into the 2nd coat of clear. I saw them before the 3rd coat, but they were too stuck to be blown off with an air tool and I didn't want to dig them out. When I was 'color sanding' I found the hairs useful to show me that I still had more clear before I hit paint. I know of at least 5 cat hairs, but I don't know how to tell where the dust is. Anyone would be hard pressed to find the hairs. I'm not worried about dust, hairs, a few fish eyes, or anything.
Thanks, considering where I started, it looks very good. Considering what I got for what I spent, I think I did well. It looks fine -probably better than new.
Even though the rear end is more than half way put back together, I still have to put the beads on the front, install the steering column, and dash and wire... so I'm hoping I'm close to half way done with the final assembly. Whoever came up with the idea for beading on the rear fenders must have 6 hands and a lot of patience.
