Whether or not you need brake work is kind of difficult to assess. The pictures don't show excessive brake drag on the rotors. Do they tend to pull to one side when braking? Is the rub you speak of causing quite a bit of drag on the wheel?
Under normal conditions I believe a little rubbing is not unusual but it is also common for the brake cylinders to have rust in them and bad seals that don't release the pistons properly.
Kurt.
Kurt.
