Dan_Morrison
Your car is a series 2 that has the earlier style rear sails. The cut down ones were changed and are only on the twin cams. As for the single wiper, your car is probably a type 54, possibly Canadian spec car. Your VIN number could be 54/nnnn or 65/nnnn. If you look at the front suspension, you can tell if it is a type 54 by one of the upper wishbones being straight as opposed to angled and fastened on the inside of the front bulkhead and not the outside like the other one. If the ignition key is on the RH side of the dash, this is another indication that the car is a type 54.
Hi Guest!
