"Different" Swap
aeronca65t
Here's a different swap: a Honda engine in a Sunbeam Minx.
https://67-72chevytrucks.com/vboard/showthread.php?t=332026
A friend of mine who owns a few 1950's British saloon cars is a big believer in swap like this... As engines in the import cars back then aren't very powerful for driving in North America, especially in non-sports models... I think a fairly common swap is a Datsun 1200 engine (ca. 1970) into a Morris Minor which improves the performance, especially if you want to drive the car on a regular basis... He also thinks a Chevy Chevette engine is a good swap just for reliability sake...
Actually a recent build he told me about, I haven't seen it since I live too far from him where he lives in Ontario... He took a Standard Vanguard Phase 1 (1948/52), restoration to original would have been quite daunting and hardly worth the money, apparently he took a modern chassis of some sort, and after sorting out issues of fit put the Vanguard on top, now again I haven't seen the car but he tells me that the car looks quite normal...
hmmm. How did that song go, again? "A Sunbeam, a Sunbeam, Jesus wants me to have a Sunbeam!"
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
tr6nitjulius General TR Different Times Same Glory! Triumph 3
JPSmit and now for something completely different Spridgets 8
K TR2/3/3A Gas tanks...two different types? Triumph 5
AngliaGT Something Different Spotted 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
J Exhaust pressure extremely different between pipes? Austin Healey 20
R TR2/3/3A different hub collars Triumph 7
M SU H-1 Carbs: Are These Just Different? Spridgets 2
Got_All_4 General Tech Different style synchros which is better Triumph 4
Joe Reed MGB A little different DGV installation... MG 12
jmayzer different part, same situation Spridgets 11
bugedd Got her leveled out, now with different wheels Spridgets 11
David Townsend TR2/3/3A And now for something completely different Triumph 2
aeronca65t This is a different Spridget Spridgets 6
M Clutch problem, a little different than usual Spridgets 8
C Wiper arms different lengths? - BJ8 Austin Healey 6
V TR2/3/3A Something Different Triumph 20
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
T General Tech How different is NPT thread from BSP thread? Triumph 2
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
KVH TR4/4A Two 4As--why so different? Triumph 4
J Different Shifters? Spridgets 3
Xte Two different springs in distributor ignition ? Austin Healey 4
CZ_Dave Well, That was different! MG 4
aeronca65t A "different" E-Type Jaguar 4
M exhaust sound different. brith/jap Spridgets 14
Sherlock Something a little, ahem, different... Other Cars 3
rlich8 TR4/4A How is the TR3 different from a TR4A Triumph 7
BugeyeNJ58 Different lengths of wiper motor cables? Spridgets 9
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
Trevor Jessie Different type of forward tilt. Spridgets 5
AngliaGT A Few Different Ones... Spotted 0
H Car's personality different based on paint color? Austin Healey 7
S And now for something COMPLETELY different...... Other Cars 7
lbc_newbie Things are different in SC! Spridgets 3
T Spitfire A different Spitfire gas cap question Triumph 3
Trevor Jessie Siblings can be so different. Spridgets 1
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
T OT - saw the hanger from a different POV today Triumph 13
Sherlock A rather different motorbike... Other Cars 6
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
G A horse of a different color Spridgets 26
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
Hap Waldrop A different approach Spridgets 12
Rob Glasgow Wow, now that feels different... Austin Healey 20
T different vacuum timing thread. Triumph 13
C Different springs for different years??? Spridgets 16
M My problem ended up being a different problem.. Spridgets 7
