After maybe 50 miles of driving with the 5 speed installed, I noticed a puddle of oil under the trans. I pulled the shift cover and found a small lake in my trans tunnel and the rear seal had spun itself out of the trans and was now on the prop shaft. Naturally I tried the easiest way to repair it by pushing it back in place, no surprise, it didn't work. I assume I can pull the prop shaft and try to re-seat a new seal. Do I just try and drive a new one in? I was thinking about using a dowel with an appropriate diameter an using the old seal in between the dowel and the new seal. I assume it goes in dry with no additional sealing compounds. Any suggestions from anyone with a similar experience appreciated.
