D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth
Garth
Would anybody be Able to tell me how to static time a essex v6 I have taken distributer out some time ago placed it back won’t start thanks garth
Number 1 cylinder at tdc, Check dizzy for correct #1 to that cylinder. Sometimes try 180* off. Move wires if you have to. Use a test light on points to set dizzy also. Have been known to use trial and error.
As said above, but I would remove the valve cover on #1 side and watch the valves “rock” to be sure you are on the correct stroke.
Skinny screw driver also helps as the piston comes up the bore.
Did not know how far he could go. Thanks, Grantura_MKI.
Number 1 cylinder at tdc, Check dizzy for correct #1 to that cylinder. Sometimes try 180* off. Mobe wires if you have to. Use a test light on points to set dizzy also. Have been known to use trial and error.
Many thanks👍
