Cant get the engine to go the last 2"
Deleted member 3577
Clutch disk on backwards?
Are you sure that it is aligned (Did you use a tool or old input shaft?)
BTW 2" is a lot...Like the nose isn't even going in???
Platinum
Yup. Input shaft ain't in the "spigot" bearing yet. Likely the clutch disk is not quite centered... patience and a good eye are the only cure. Force will just get ya in trouble /ubbthreads/images/graemlins/wink.gif
LLAngus
/ubbthreads/images/graemlins/iagree.gif /ubbthreads/images/graemlins/iagree.gif /ubbthreads/images/graemlins/iagree.gif
Time to take it easy. You could do real damage here.
/ubbthreads/images/graemlins/cowboy.gif
647F
should i be jacking the engine from underneath? should i move the lifting point to the back of the engine (which i did)...
647F
auauauauauaughghghghgh!!!!!
i just deleted my last post!
so here it goes again!
I pulled the engine out, checked the clutch alignment (with the tool, it slipped in and out very easily)
Rehung the engine, and started over.
Now i have everything within an inch of going home. The ring gear is just inside the bellhousing and is evenly spaced all the way around...
nothing, it will not budge!
647F
oh, i also used a light oil to coat the tranny input shaft and the inside of the clutch, just to make it slide easier, as i didn't want to you use grease.
someone call me...707.310.2138
Platinum
Not a thing! In the 'trade lingo' "...you just ain't got your tongue in the right place yet!"
"Wiggle" the box or engine about while keeping rearward pressure on it. If you're 1" away you're at the bearing/flywheel with the input shaft tip.
Question: Did you back off the clutch cover bolts and really re-align the disk? The tip of the tool in the crank bearing and a careful check to be sure the tool is in the exact center of the T/O bearing face of the cover? Just "thinking out loud" here.
tony barnhill
Great Pumpkin - R.I.P
Might I make a suggestion: pull the engine again...pull the transmission...mate them on the floor of the garage & then put that assembly in the car...you're gonna be playing with that alignment for days & then you've gotta reach all the bolts on the bell housing...quicker & easier to do everything on the floor.
I agree with Tony. I tried to install an engine with the tranny "insitu" one time. What a pain in the arse!
In my opinion, it's a WHOLE lot easier to mate the two on the garage floor, then install as a unit.
ps...try doing this with an MGC block sometime!
Best wishes...walk away and come back refreshed and non-frustrated....your day will go a LOT smoother.
Platinum
Tony, I got him to ~promise~ he'll do it *right* the next time /ubbthreads/images/graemlins/wink.gif
Now waiting for the "AH-HA!" post here. Almost suggested he pull the box, but I'm sure he's millimeters from having the input shaft snoot just "fall" into place. We'll see.
tony barnhill
If that's the case, then I would suggest repositioning the car...lower the back of the car...remember, you're transmission is solidly attached to the car & your engine is 'floating'...there's almost no way to stab the engine with the car level....or, you can raise the rear of the car - it doesn't matter
Platinum
He's got the gearbox well and truly "up" as far as it will go, the engine swinging from a forklift. He ~should~ be able to "juke" it around enuff to find the spigot bearing center, has the bellhousing half way over the ring gear already with even distance all the way 'round. Close... very close. Doing this with the box in the car is so frustrating I swore years ago it was worth every second it took to pull the engine/box unit intact. With the CB cars, I got so proficient I could have the thing sitting in front of the car in under an hour. Kinda sad as a "claim to fame" but there ya go. Reinstall took a bit longer but not much.
647F
i just cant believe i couldnt get it in, but doing this lone is not the most pleasant job. i am going to yank the tranny and set it up on th floor
i just hope the tranny bushings are in good shape.
Platinum
Now I'm not sure if I should cry or rejoice. Doing this alone is a real bear, but pulling the box out and doing the job on the deck IS the better plan. Bad bit is: it'll pro'lly FALL into the engine on first go this way: Something to do with Edsel Murphy and an unwritten corollary, I'm sure. Keep us up on the 'haps'?
...and take your time, be safe... alone you've gotta scream REALLY loud for anyone to hear ya if you get "trapped" somehow.
"This is NOT a drill." /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/devilgrin.gif
Long, deep breaths....take a break....have a beverage....walk away from it....don't get discouraged.
Chances are, it will line up first try on the garage floor!
tony barnhill
Oh, you're going to find that the transmission bushings are shot - just accept it & get new ones....I hope your car is high enough that you can drop the transmission straight down & pull it out.....if not, start jacking
647F
[ QUOTE ]
[/ QUOTE ]
ok, tranny is out...the bushings kinda parted on the way.
now, can i install the whole engine/ tranny set up back under the car with out the tranny bushings, and install them later?
(i have to move the car from its current location)
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
T MGB-GT cant rails on 1967 MGB GT MG 12
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
T TR4/4A Heater control valve - cant completely turn off Triumph 3
F White smoke and I cant figure it out. Spridgets 17
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
UmmYeahOk GT6 Cant restore my GT6 - what do I do? - [long] Triumph 39
justin_mercier Wedge it's true, you cant own just 1 LBC... buying a TR7 Triumph 15
glemon Help Cant Bleed Brakes Triumph 15
jaegzie Ive searched/cant find thread master cylinder BE Spridgets 6
texas_bugeye Blown head gasket that cant be good! Spridgets 10
S Cant remember where they go !! Spridgets 9
zimmy cant... install... windshield.......help wanted! Spridgets 15
B Help..Clutch not Engaging..Cant Shift Spridgets 4
Woodie Cant find my reference papers Spridgets 4
A Cant bring up private messages--Help!! Triumph 2
O have pics cant post Triumph 22
kbash OMG I cant beleave this happened to me :[ MG 0
G So why cant you do this here? Other Cars 9
A Cant remove crank sproket??????? Triumph 13
1 MGB My new 1977 MGB? cant turn distributor MG 3
A looking for a piece that i cant find MG 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
