Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Had a problem once with too much lube in the pilot shaft bearing and the input shaft would not go in because of the hydrolics of the grease. I agree with Doc and Tony, put them in the car together--just watch out for your fingers when you align the trans in the tunnel.
It likely would have gone in but we (read:I) didn't account for the possibility of machine swarf in the disc splines... figured an ~engineer~ was doin' the job and tested the fit ahead of time... /ubbthreads/images/graemlins/jester.gif
...just takin' th' pi** outta ya, Doug! /ubbthreads/images/graemlins/devilgrin.gif
[ QUOTE ]
[/ QUOTE ]
the worste part being that i should have know to test fit it before hand /ubbthreads/images/graemlins/hammer.gif
anyways i still havent got the engine as i have been so busy with work to get to it.
