Cant get the engine to go the last 2"
tony barnhill
Great Pumpkin - R.I.P
Noooooooooooooooooooooooooo....you really don't want to do that....those bad boys are hard to get in when they're shot & even harder when they're new!
647F
[ QUOTE ]
[/ QUOTE ]
nuts!
Deleted member 3577
So far as the arachnid problem goes.......I think that was an appropriate, measured response.
I was under a car, in the yard one time, when a mouse ran across my chest and into the armpit of my jacket.
Holy screaming willies......After I got out from under the car & removed the frightened creature, I looked around to make sure no one saw me. Not a good place to loose respect.
One guy I know caught his shoe on fire while torching off a part....Every time he comes in, the owner's son & his fetcher buddies hop around on one foot and yell.
He will never live it down.
hehhehe - screamed like a little girl did'n ya? Mice touching body parts are not fun. I did a year as a pest control guy... I understand. I actually cried one time when a snake found it's way up my pantleg while I was in the crawlspace under a house doing a termite job.
647F
ok, dammit, here i am almost 24 hours later and no where closer to solving this problem! i can get the tranny upto the ring gear and that is it!!! not a bloody f-ing milimeter farther.
647F
all i can think of is to take a grinder to the nose of the input shaft, that way the stupid piece of **** will go on the goddamn hole. /ubbthreads/images/graemlins/mad.gif
647F
who ever said it wasn't getting past the clutch was right, there was a bur on the clutch and i was never getting the input shaft into the clutch...24 hours of work later...should have slid the clutch on the input shaft before i installed it on the engine.
Deleted member 3577
That does remind me of a problem I had with a new input shaft one time.
I just bought a close ratio set-up for an MGA tranny.
The new 23 spline shaft was a very tight fit on the clutch disk.
I had to use an old clutch & some mildly abrasive paste to polish the splines so the new clutch would slide.
Also, I had problems with the 3 edges of the pressure plate (where the torque straps connect) rubbing on the bell housing. My solution was to machine off about 1/8" of material. But then I had to have it rebalanced.
So much for quality control on replacement parts.
jlaird
Oh, pre fit everything old and most of what is new. If a prob can arise it will.
Grats, you makeing progress.
647F
[ QUOTE ]
[/ QUOTE ]
tell that to my back...
Platinum
I made the mistake of *assuming* you'd done that. Ever so sorry for the lack of thoroughness as regards a step-by-step. ...I shoulda asked.
*Advil*
jlaird
Doc, you should be ashamed of your self, inclomplete instructions. You must think you are a real Doctor. hehehe
Platinum
Yeah, I'm hangdog over it. /ubbthreads/images/graemlins/tongue.gif
Live and learn.
647F
dont sweat it, i should have know better...never ever assume that new parts are going to fit.
the worste part was that it took me about 5 minutes to make it all better...
Nunyas
*oof* I just love when it takes me 5 minutes to finx a problem that I've been racking my brains over for hours.... NOT! Glad to see you got it all together finally. I'll have a coffee in your honor this morning. /ubbthreads/images/graemlins/smirk.gif
Doc, advil? Not "vitamin M"? hmmmm... or was Motrin not invented when you were in the military? While I was in the Marines, Motrin was the Corpsman's wonder drug... Vitamin M is what we came to know it as...
Advil, Motrin...it's all ibuprofen 200mg in the over-the-counter variety. I live on it..
Your resident pharmacist....
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
T MGB-GT cant rails on 1967 MGB GT MG 12
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
T TR4/4A Heater control valve - cant completely turn off Triumph 3
F White smoke and I cant figure it out. Spridgets 17
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
UmmYeahOk GT6 Cant restore my GT6 - what do I do? - [long] Triumph 39
justin_mercier Wedge it's true, you cant own just 1 LBC... buying a TR7 Triumph 15
glemon Help Cant Bleed Brakes Triumph 15
jaegzie Ive searched/cant find thread master cylinder BE Spridgets 6
texas_bugeye Blown head gasket that cant be good! Spridgets 10
S Cant remember where they go !! Spridgets 9
zimmy cant... install... windshield.......help wanted! Spridgets 15
B Help..Clutch not Engaging..Cant Shift Spridgets 4
Woodie Cant find my reference papers Spridgets 4
A Cant bring up private messages--Help!! Triumph 2
O have pics cant post Triumph 22
kbash OMG I cant beleave this happened to me :[ MG 0
G So why cant you do this here? Other Cars 9
A Cant remove crank sproket??????? Triumph 13
1 MGB My new 1977 MGB? cant turn distributor MG 3
A looking for a piece that i cant find MG 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
