Thanks, I think I will skip them!
The factory found that without the dust shields the brakes wore faster. I have a BN4 (originally with drum brakes) that I converted to discs. The disc pads might wear out faster, but we drive so little per year, the rubber parts will expire due to time first. So, don’t worry about it.
I didn't notice the stops in the thunderstorm near Mt. Shasta were any longer than normal. Then again, I couldn't see where I was going (no one else could either).I've also read that running without dust shields can cause the first stop when running in the rain to be a bit longer.
Steve,
This is at full bump and lock and the clearance is about 1/8". What I think I did differently than you is the fabrication and placement of my hard line to braided steel line bracket. I angled it down about 40 degrees which brings the connection below the shock tower.
Well, I didn't run into the back end of Irene's BJ8, which does have them.John - respectfully, you weren't in a position to try exactly the same stops with shields in place.
Since my conversion is on a BN4, I would have to buy shields and would probably have to modify them.
To summarize: the best-handling (lightest) brake upgrade would be aluminum 4-piston calipers (AHspares, Wilwood) with the lighter pre-BJ8 3/8" rotors and no dust shields.
Would the aluminum calipers work with the thinner pre BJ8 calipers or would the piston travel be too much?
