I've been struggling to get my BJ8 to start. I decided to get back to basics and removed the valve cover so I could check to see if the both valves on cyl # 1 were closed when the the car was supposed to be at TDC. I connected a 12v light bulb to the coil and ground it with the ignition on.
Well the light did not come on at the TDC or at 3/4" mark BTDC. So I rotated the crank pulley clockwise (if you are standing in front of car and facing the engine) until the light went on. I had to rotate the pulley @ 2" before the light went on.
Is my distributor stuck on wrong or did the timing chain jump a few teeth?
What do i do now?
Thanks
Jorge
1965 BJ8
What do i do now?
Thanks
Jorge
1965 BJ8
