BJ8 Batteries
Legal Bill
Well, after 13 years, my battery is dead. I guess they don't make them like they used to. :rolleye:
So before I just run out and find one that fits, I thought I'd come here and ask the cool kids what they are using these days. My car is pretty original so I'll probably end up with a black case lead acid battery, but I'm interested in hearing your experiences. I noticed my old battery was rated for 700 CCA. That seems high, but I can't really argue with the experience. The battery really did its job. SO what ya using and what do ya recommend?
Thanks in advance for your thoughts.
PS, yes, I did a search. I stopped looking at the results after page 3.
Re: BJ-8 Battery discussion
I'm impressed--and delighted--whenever a parts house actually lists parts for Austin-Healeys. I've had the X-Power AGM shown here in my BJ8 for several years:
https://www.batteriesplus.com/battery/car-and-truck/austin=healey/3000/1967/l6-2.9l-300cca
The main issue is leaking; I've had to pull my gas tank and flush my boot with baking soda due to leaking batteries twice; once was due to my voltage regulator overcharging. The AGMs are pricey, but should last a long time and are less inclined to leak (I hope).
I had a discussion about batteries with Mike Martinez, who owns Star Electric. He said almost all batteries are now made in Mexico--likely due to little/no environmental restrictions and cheaper labor--and are, in a word, crap. He used to recommend Optima, but said they've gone downhill since they're now made in Mexico. Interstate used to be a go-to brand but now, you guessed it, Hecho en Mexico, and I had a couple in my old Mustang that only lasted a couple years (though I have a couple Interstate golf cart batteries in my BN2 and they've been OK for several years). He did recommend Odyssey AGM. The one brand I know of that's still made in the States, and recommended by Mike, is Deka. I put one in my old Mustang a couple years before I traded it in and it worked well, and have a 6V in one of my tractors. They are made by a family-owned business in Pennsylvania and sold by some parts house chains, 'Parts+' for one and a local battery store. I use Group 24 in my BJ8 and 17H--no one seems to make/sell 17L anymore (supposedly Antique Auto Battery was resurrected but I don't know its status)--in my BN2/100M.
I keep my Healey batteries on 'smart' chargers when not in use. I like Battery Minder (they have one especially for AGMs). I feel they pay for themselves in the long run.
L
Legal Bill
Thanks Bob. My old battery is a group 27. I was going to stick with that for the extra cranking power. But maybe a 24 with a three year warranty would be better than a 27 with a two year warranty.
The AGM in my BJ8 spins the engine over quite nicely, and it has good compression (170psi +/- on all six).
Edit: It has 840CCA and 5-year 'free replacement' warranty (presumably not pro-rated).
Keoke
Well:
ID have to wait on SS to afford one today----LOL
British_Recovery
Bronze
My two cents on batteries in the boot: A group 27 fits the original tray and will have the posts to the far side, away from the original metal bracket. Harder to reach with jumper cables, but overall where they should be. If the polarity for grounding has been changed on your car, and you want to maintain that orientation, a group 27f is what you need.
The negative post on the 27f will be at the rear and away from the metal bar.
People using the original metal bar with the posts on the near side run a risk of a major short circuit, should the bracket loosen and contact both posts. Regardless of the battery selected, please consider a possible short circuit, with the mounting hardware and also any loose trunk contents.
Bob
JamesD BJ8 Top Frame Bumpers Austin Healey 6
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
B BJ8 door hinges Austin Healey 7
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
B Wanted BJ8 door hinges Austin Healey Classifieds 0
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
M 1966 BJ8 Top Austin Healey 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
T BJ8 Carpet Padding Austin Healey 4
S BJ8 Rear Seat Side Panels Austin Healey 3
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
66healey BJ8 shifter spring install Austin Healey 2
P BJ8 Frame Rust Options? Austin Healey 14
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
C My BJ8 Barn Find Austin Healey 15
J Nut size for BJ8 center console trim piece Austin Healey 8
M BJ8 Frame Dimensions Austin Healey 2
