TR2/3/3A back half to chassis questions
F
Frank Canale
The closing panels are all welded in. I am very happy with the results and looking forward to moving to another area.all the seams turned out nice and tight.
Driver side closing panel welded in.
Passenger side closing panel welded in.
F
Frank Canale
Thank you Graham, so far so good. Also very happy with the bumperette mounting. One of the bumperette brackets was bent up and had to be bent back to match the other but I am lucky I found both of them. on the first install made a rookie mistake and installed them upside down. I knew something was wrong but had to check the forum and sure enough upside down, much better now.
maybe I will have to play with the vertical alignment as the driver side seems a little off but just first install.
The passenger side looks much better, not sure if cameras angle is making the driver side look off but should not be too hard to adjust. One question I have, The new lower closing panel does not have the notches cut in it yet but I do not see the purpose as the bracket clears that notch and I was able to install the brackets without any obstruction that the notch was needed. What is the purpose of the notch above the lower part of the bumperette mounting bracket? Frank
sp53
What does an end view look like of the bumperetts? They can go upside down; they should be vertical. The notch is there for the bracket. I will try and get a pic later. But it looks like they should be fine and if wrong can flip right over.
steve
F
Frank Canale
Sorry, not the best photos but a little cramped in the shop. Need to get rid of some of the clutter but soon as I do I will need something I just got rid of. Frank
Graham H
Frank, I think the cutout is to allow for any small misalignment of the bracket or a slite nudge on a curb could make contact, I have more clearance on the left than the right, I think you will be happier with it than without.
Graham
F
Frank Canale
Thank you Graham, excellent photo and explanation. I now see that I need to make an adjustment to the mounting bracket. The bottom of the bracket is too low, the last 2 bends need to move so the bracket is not below the bumperette and closer to the notch. This will also bring the bottom of the bumperette out and bring it closer to vertical. Frank
I feel like I have the rear body mounts correct and so I will have no problem adjusting the bracket. I feel much better seeing your photo and that it seems like an easy fix.
F
Frank Canale
The driver side is very close and all I need to do is cut the notch in the new closing panel to match the notch in the rear apron. It is the details like this that take the time but also make a big difference in how the car looks. Frank
CJD
Every time you post new pics I find something else that impresses me. This time it's not just the car, but the very nice jack or frame jig you are using!
F
Frank Canale
Thank you John. I guess it has been a couple years ago I built my rotisserie knowing that some day I would get to use it. For now it is used at the back with custom brackets that use the rear spring hanger as a mounting point. For now the front is on large jack stands. I had to put some wooden boxes under the frame at the back so I could lower the rotisserie and I could mount the as I have learned from the spare parts catalogue is called the over rider bracket. Getting to this point I have had to step back and take in just how far my car has come. There is a long way to go but I can start to see some of the pieces that have been repaired long ago start to come together. I definitely did things out of order but that is ok we are all different and do things at our own pace. Frank
Graham H
That's my other old chariot 1926 Chevrolet Tourer, I completed the restoration about 23 years ago.
Graham
F
Frank Canale
I was wondering the same thing. WOW, SUPER WOW, That is a beauty. Frank
Graham H
Thank you, it was a one owner, Uted during the War to gain extra fuel coupons as a farm vehicle and all the pieces were still scattered around the farm. This photo is what I took home arround 1985.
Graham
Graham H
It took me about 10 years of scrounging and begging, some parts were still available new in Australia some from the USA but got there in the end. My future Daughter in Law spotted it in the back of my shed one day and declared that she wanted to be driven to her wedding in it and the date had already been set for six months from then, so I had a deadline to meet.
F
Frank Canale
Great photo, also great memories and stories of that day I am sure. Frank
F
Frank Canale
Hi Steve, yes they will flip over and that is how I had them at first. All the pictures I have looked at have the top of the bumperette even with the top of the spare tire opening. If you flip them they hang down below the bottom of the rear apron and the top of the mounting bracket is visible. I am confident they are on right side up. I plan to take another look at the mounting brackets tonight. Frank
Got_All_4 TR5/TR250 Only half of the tack is lit Triumph 14
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B BJ8 Half-Shaft Oil Seal Austin Healey 5
SD Bugeye Half capacity of the fuel tank Spridgets 10
tahoe healey half car cover Austin Healey 3
D Front suspension half moon cotters Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Jim_Gruber Looking for back half of PS Floorpan for my BE Spridgets 6
S TR2/3/3A Well onto the second half Triumph 2
Boggsy64 MGB Half shaft question MG 2
H brake calliper half seal size Austin Healey 4
Bremer TR2/3/3A TR3 half doors Triumph 11
G Half shaft removal Triumph 3
Jim_Gruber Progress - Suspension half done yeah! Spridgets 2
Brian_James Wire wheel half shafts and bare 1275 block Houston Spridgets 1
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
hondo402000 new CV half shafts Triumph 49
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
ScottTR6 Half shaft replacement Spridgets 7
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
T Half way? Triumph 189
tweety Changing a half axle Spridgets 1
S I hope my car looks HALF as good as this one...... Jaguar 6
jvandyke weird half top, soft targa? Spridgets 10
mrv8q TR6 TR6 half-shaft removal Triumph 15
B 3.9 Diff/half shaft/spline question. MG 2
J Spitfire Spitfire Half shafts Triumph 3
F Removing Axle Half Shaft [Tube Type] MG 4
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
JPSmit Help #3 - diff + half shafts now Spridgets 2
G Ninety nine and a half just won't do.... Triumph 15
drooartz Tips for brake drum/diff/half shaft removal Spridgets 14
G Flag at Half Mast for a While at AAW Triumph 6
Z Axle half shafts Austin Healey 0
GB1 Half Shafts - Hardened Spridgets 18
A Introduction [half a day late] Triumph 6
bighly Dream Machines in Half Moon Bay CA Austin Healey 1
martyc Help! Stupid Half-Tonneau Question MG 3
J TR6 TR6 - half top/bikini top? Triumph 1
D Stag Stag half shaft removal Triumph 6
TypeRboy Half way there.. Lotus 1
Basil Half-axel U-joints - HELP! Jaguar 6
A BN2 Chassis Alignment Austin Healey 8
RJS TR4/4A Chassis Buffeting(?) Triumph 10
apbos The next rabbit hole. Help ID the chassis. Racing 27
apbos Help Identify this car chassis Racing 20
