Thank you Graham, so far so good. Also very happy with the bumperette mounting. One of the bumperette brackets was bent up and had to be bent back to match the other but I am lucky I found both of them. on the first install made a rookie mistake and installed them upside down. I knew something was wrong but had to check the forum and sure enough upside down, much better now.
maybe I will have to play with the vertical alignment as the driver side seems a little off but just first install.
The passenger side looks much better, not sure if cameras angle is making the driver side look off but should not be too hard to adjust. One question I have, The new lower closing panel does not have the notches cut in it yet but I do not see the purpose as the bracket clears that notch and I was able to install the brackets without any obstruction that the notch was needed. What is the purpose of the notch above the lower part of the bumperette mounting bracket? Frank
