Looks great Paul. I thought you would have had it installed by now
Looks great Paul. I thought you would have had it installed by now![]()
The TR4 transmissions are fully synchronized while TR3 lacks a synchro on 1st gear. That would be an upgrade.I'm new here. Just curious, but what is the story with these older transmissions? My cars will never be show cars, so I don't have a need to keep them original for "value" or "show." I'm pretty sure all the engines and transmissions in the MGAs my dad had are somewhat original, except for swapping a 1500 for a 1600 engine. I don't know why, but the previous owner of the TR-3 said he put a TR-4 transmission in it back in the '70s. Other than catastrophic transmission failure, would there have been a reason to replace the TR3 transmission with a TR4's? I hope your wait isn't too long and you enjoy the new transmission.
The TR4 transmissions are synchronized while the TR3 lacks a synchro on 1st gear.I'm new here. Just curious, but what is the story with these older transmissions? My cars will never be show cars, so I don't have a need to keep them original for "value" or "show." I'm pretty sure all the engines and transmissions in the MGAs my dad had are somewhat original, except for swapping a 1500 for a 1600 engine. I don't know why, but the previous owner of the TR-3 said he put a TR-4 transmission in it back in the '70s. Other than catastrophic transmission failure, would there have been a reason to replace the TR3 transmission with a TR4's? I hope your wait isn't too long and you enjoy the new transmission.
You should post this on the Triumph forum, you would get more responses on the subject. I know nothing about a Triumph, sorry. PJThe TR4 transmissions are synchronized while the TR3 lacks a synchro on 1st gear.
I understand about all the prep-work. I replaced the original Triumph transmission in my TR6 with the 5-speed Toyota kit made by HVDA.Elliot, I'm sure you know there's quite a bit of prep work to put one of these in, not a take it out of the box and drop it in place. Actually, on a TD the earlier kit where the engine is moved forward would take less work. A TF has a crossbar brace under the water pump from fender to fender that needs to be modified to move the engine forward, plus it would be easier on a TF just to pull the whole front of the car off! I didn't want to go that route so I chose the latter kit and cut the rear cross member. It's a well-designed kit using an excellent transmission. Just a lot of work!![]()
Then, if the exhaust pipe is too close to the bottom casting clamp when put back together I'll need to take it to a muffler shop and have a slight bend put in it. It's stainless and hopefully, there is enough flex in the pipe to allow a slight bend, it has to be at least 1/2 inch below the bracket. More
!Nice looking job with the safety wire. I would have thought you'd have done the inserts while waiting on the gearbox!Slowly getting there.
All's left before mounting the transmission is putting the inserts in the sump for the transmission bolts.![]()
Well, miserable weather here Doc, snow, sleet, 17 degrees and very windy, slows me down a bit as I have to walk about 200 feet to the shop. I'm doing the car in the warm garage and every time I turn around I need something else from the shop. I'm getting lazy and hate the cold more every year, I can't wait until summer! But we'll get her done before driving weather!Nice looking job with the safety wire. I would have thought you'd have done the inserts while waiting on the gearbox!
