DNK said:The orange can be painted over.
Consider size and weight first. Then the fact which has the nicest FI possibilities
rick_ingram said:DNK said:The orange can be painted over.
The small block Ford does no weigh that much more than the stock 1800cc block...and if you use aluminum heads. you can decrease that weight.
One of the only drawbacks is having to modify the front crossmember to get the block low enough to close the bonnet and have room for the sump.
There is a LOT more aftermarket support for the SBF vs the BOPR block.
Bob Claffie said:If you think finding one of those BOP 215's is tough wait 'til you try to find s stick shift bell housing ! Bob
JPSmit said:
DNK said:The Ford a shorter unit?
PAUL161 said:As far as I can tell, the SBF will add about 40 pounds to the weight of the car. But, with the elimination of the bumpers and going with fiberglass replacements, weight wise, it won't change that much as far as the suspension is concerned.
<span style="color: #990000">Rick, is there a set of drawings for the cross member mods?</span> PJ
