2004 Discovery Oil Pump Faailure
E
eyesie
My Daughter has a 2004 DIscovery that has just broken it's oil pump. The engine appears toast. This car is has 62k on it. We have been told that this is a known problem by L/R, but they wouldn't do anything about it unless the engine failed. Is anyone aware of this? Does anyone have any info on class actions etc? $8k+ to fix this is a lot of money if the factory were aware of the issue. Any help would be appreciated.
Thanks
Alan
R
RonMacPherson
There is a diagnostic tsb for symptom resolution. LR, as far as I know, only steps up to the plate if a failure occurs. Seems some front covers were improperly machined where they do not mate up to the front of the engine.SO the pump is not turning completely parallel to the crank and front of the engine. Wipes out the rotors of the pump after many miles. If she ever took it to a LR dealer complaining of engine noise, ticking, or oil light coming on, before the warranty expired you have warranty leverage. If not.....
So it is not a product recall, but you might contact NHTSA and see what they say..
E
eyesie
Thanks for the info. What does tsb sran d for? "? Service bulletin?
WedgeWorks
We have 3 rover blocks fail because of this same oiling issue in TR8s. It turns out the front cover for the 4.0/4.6 litres does not have locating pins as the older and revised new covers do. This means it is a 50-50 chance of getting the pump aligned right. If your off a tad bit it prolongs failure. In our cases we were off enough to kill an engine in about 4 to 5k miles. LR really has not fessed up to this but in the early days of a LR under warrenty they would fix it by getting a new engine and dumping it in. We have about 20 complete long blocks that all have the timing covers on them in UNKNOWN condition but were replaced as warrenty items. I would suspect that is the cause/reason. Good luck!
M 2004-2008 XJ8 Air Suspension Reliability and Problems Jaguar 0
B 2004 vanden plas Jaguar 1
69MGC 2004 MG Brochures MG 6
S 2004 X-type Transfer Case Jaguar 2
S Please help me with TVR Sagaris 2004 TVR 13
tony barnhill Vintage Mint Green 2004 Thunderbird Other Cars 35
bigbadbluetr6 VTR 2004 pictures Triumph 14
StagByTriumph Triumphest 2004 in Lake Tahoe Nevada Triumph 1
Sherlock Pictures from Micro Car Nationals 2004 Other Cars 5
Cottontop Conclave 2004 in San Antonio Austin Healey 0
tahoe healey 2004 Tahoe conclave over Austin Healey 6
tahoe healey 2004 Tahoe gathering Austin Healey 0
X MiniMeet 2004....who's going? British Motor Corp 22
B Dream Machines 2004 Austin Healey 14
jfslenes Muscle Mania May 16, 2004, Albuquerque Sunbeam (Rootes) 0
G 2004 XJ VDP Jaguar 1
X MiniMeet 2004 British Motor Corp 3
J Elise to Arrive in U.S. in May 2004 Lotus 3
P October 2004 Car of the Month... Austin Healey 8
C 2004 XJR Jaguar 2
J Who are the customers of Discovery?? Rover / Land Rover 0
sparkydave Odd discovery, but still ran OK Spridgets 1
R 2003 Discovery restoration story Rover / Land Rover 11
M BN1 Overdrive discovery Austin Healey 12
pkmh Interesting little jack stand discovery, "Drednaut" Austin Healey 0
dougie A Timely Discovery Austin Healey 11
S Wedge tr8 starter swap with a 2000 discovery starter Triumph 7
Rut Weekend discovery Spridgets 6
B Heater discovery Spridgets 16
H Shocking Discovery and Conclave Bound Austin Healey 0
R Important Discovery MG 6
T Interesting discovery on the carbs today Spridgets 15
sjuengst Cockpit heat discovery Austin Healey 7
mrsprite Bugeye on Discovery HD Theater show 'Wreck Rescue' Spridgets 3
5 Discovery alarm issue... Rover / Land Rover 3
pjsmetana TR4/4A TR4 on TV - Discovery HD Theater Triumph 3
M TR2/3/3A TR3 camahaft discovery [Kas Kastner D Grind] Triumph 13
jaegzie Rather disgusting discovery Spridgets 3
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
Tim Tucker TR4/4A TR4 on Discovery HD Theater Triumph 0
kennypinkerton Problems with Discovery? Rover / Land Rover 5
J Bugeye on Discovery Channel Spridgets 14
W An interesting discovery Spridgets 39
texas_bugeye Dizzy vac question [NEW DISCOVERY] Spridgets 2
G Ralph Lauren's car collection on Discovery Triumph 0
BritCarFan 1998-2002 Land Rover Discovery Rover / Land Rover 1
martx-5 TR2/3/3A TR3 Project Discovery Triumph 9
W 1995 4.0 SE/2002 Discovery II Trailer Hitch Rover / Land Rover 1
S Another Alpine race car discovery Sunbeam (Rootes) 2
Mwalsh Top Gear on Discovery! Other Cars 16
