BritCarFan said:
I've been looking into buying a Lincoln MIG welder at the Home Depot. The search is narrowed down to a 110V or a 220V unit.
I'm leaning towards the 110V because I don't have to install a seperate circuit to the garage.
Any thoughts?
A couple of things to consider here.
What type of welding are you going to endulge in?
I.E. light guage material, small {short}welds?
Material 1/4 in. or smaller?
The 110 welder will work just fine for this scenerio, as suggested you will want the gas capable model welder. {you can always add the gas bottle later if desired.}
If you plan to do heavy fabricating 1/4 in. material and above, long welds frequently. You will want the 220 machine.
The difference bieng, with the 220 machine you will have a longer duty cycle {the ability to weld for long periods of time with out stopping.} Plus a higher volt/amp range capability. {for welding thicker materials} For more information on Welding processes and welding machine types and uses see threads posted by me in this {tools} forum or the articles in the wiki. Hopefuly these articles will answer all of your questions, if not feel free to P.M. me for any further information you may desire.
For MOST hobbyists the 110 v welders are quite sufficient.
