Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
It's just monitoring system voltage so get a lead to + from any convenient hot post and run a second lead from the other the other contact to any ground. If the posts are not marked check polarity with a set of test leads.
I guess it depends on what you are trying to monitor. Voltage @ the battery will tell you the overall condition of storage in very small increments (difficult to see on the gauge)and you would need a relay or switch to disconnect the gauge. The voltage output of the generator or alt. can be important in terms of are you adding to the electrical system; however if the voltage does not make it back to the battery then all is for not. The easy way is to watch the voltage @ the switched side of the key or ignition. Looking @ voltage going to the ignition will allow you to see the effects of the charging system. Just after start (low voltage), increase RPM and watch the charging system overcome low voltage.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
