TR4/4A Vapor lock????
The most insidious thing is a fuel hose that has swelled internally.Always use fuel injection grade
hoses.Todays gas is crap ,and destroys the made in china regular hoses. The hose at the tank
will give you just a dribble at the pump if this is the case.
Even worse is a leaf from a big tree(sycamore ) that floats about randomly stopping fuel.
This causes multiple changes of fuel pumps for the next 10 years.........
Mad dog
Possible clog in the fuel system. My TR 3 did just that. The line from the tank to the pump had a partially collapsed section and fine grit from a rusting tank would collect and prevent fuel from passing. After sitting and the relief of suctioning the fuel in the line cleared and the car ran until the grit gathered again. New fuel line, no problem. Now the grit is getting collected by the filter in the pump and an in-line filter.
Thanks
I had weird fuel delivery issues and I put an airline on the fuel pipe from the pump to the tank. The pressure rose then just gave as if a blockage had cleared.
Drove ok for a bit then returned.
I checked the pipe work and some PO had put a rubber pipe to join the metal pipes from the tank the join was about the position of the front of the rear wheel.
See the attached plan.
Swapped it out and cured all my fuelling issues as the pipe had degraded inside. In just the shorted gap between the 2 metal pipe ends.
3-4 miles is not enough heat to cause cavitation. It is enough to heat a dodgy capacitor to failure. Re-starting after a cool-down is classic capacitor failure. See if you can find one that is not made of Chinesium.
Have you fixed the problem? If not, I know we all have our stories. But if you chug, miss, then stall, and you’ve tried all the standard, obvious things, like plugs, points, fuel, timing, and capacitor, you might give some thought to the elusive problem I had and discovered months and months after I first started hunting for it.
It was this—a fuel pump (a new one in my case) putting out nearly twice the factory recommended pressure of 1.5 to 2.5 psi. Seriously, I was at 3.9 psi and suffered constant stalling due to flooding. Everyone kept saying “vapor lock,” but no way. The problem was that pump. I installed a pressure regulator/reducer and my TR runs better than ever, and stalling is a distant memory. Makes me want to ask if you installed a new pump that could be the culprit, though an older pump could pose the same problem.
A cheap gauge from Harbor Freight can help you check. You can disconnect the fuel line at Carb No. 1 and clamp that gauge into place in less than five minutes. But while using it, don’t let it hang or dangle anywhere near the fan or fan belt. Just warning. . .
Check your low tension lead on the coil. Vibration from engine can compromise the wire connection right at the female connector. When issue first manifest's itself, it is fine on cold engine. Heat exacerbates the problem. When hot, the motor will begin to mis-fire under load. Then mis-fire regularly. Then completely die. It's as if someone turns the ignition key off. I experienced this a few years ago. The issue progressed over several months before I could diagnose it.
Just a thought. If that is the issue, it's a $0.10 fix
Thanks Bob, I am going to check fuel pressure and see if maybe it is to high and finally flooding out. There is no misfire, it just kind of sounds like you are running out of gas and dies.
Thanks KVH I bought a pressure gauge and I am going to check. I hope that is it, should be easy fix if it is.
Usually when my Land Cruiser fuel filter was plugged (rust in the tank) and it was starving for fuel, it would loose power, and buck, and spit and backfire as the mixture got leaner & leaner.
Yours sounds different to me.
Is there a rubber line before the carbs? Clamp it off, and demonstrate what “running out of gas” sounds like in your neighborhood (close to home) so you can be sure the symptoms are the same…
Couple of things. It’s best to run the engine with the gauge set up, but if your pump has the manual primer lever, you’ll get a preview by trying that, though your fuel bowls, of course, will need to fill up first. The spare rubber hoses that come with the Harbor Freight gauge work fine but you might need some extra 1/4” rubber hose depending on where your steel line ends. Mine was easy, because my steel line was only about 6 inches from carb No. 1. You won’t need any of those other silly looking fittings. Just go with hose and small clamps. You may need a little lithium grease to avoid the hoses binding.
I totally ignored the instructions that say to attach the gauge down near the fuel pump. What a nightmare that would’ve been. They only say that because they’re assuming, like for most cars, your line from there is rubber fuel line that will distort the reading, but on a TR4, as you know, it’s all steel to the carb, except for the short run at the end, so the gauge can go right there and it will work fine. Just keep it away from the fan belt, fan and generator. It’s easy to set up out of the way. The entire testing, hose clamps and all, might take ten minutes. It’s simple. But read the gauge properly. Look only at the fuel pressure read-out scale.
If you’re above 2.5 I’d be concerned. Mine was 3.9. A disaster on the road.
If yours is high, you might do what I did. I did not want to buy and test new pumps, nor did I want to play with the internal pump spring to find a balance. Instead, I installed a pressure regulator and it has worked like a dream. If it comes to that, I can give you the run-down and exactly how and where to install it.
Good luck.
Couple of things. It’s best to run the engine with the gauge set up, but if your pump has the manual primer lever, you’ll get a preview by trying that, though your fuel bowls, of course, will need to fill up first. The spare rubber hoses that come with the Harbor Freight gauge work fine but you might need some extra 1/4” rubber hose depending on where your steel lie ends. Mine was easy, because my steel line was only about 6 inches from carb No. 1. You won’t need any of those other silly looking fittings. Just go with hose and small clamps. You may need a little lithium grease to avoid the hoses binding.
Good luck.
Thanks KVH for the info. My TR4 already has a regulator so I will be hooking gauge to it. Sounds like you have a lot of knowledge on TR4s, so this probably won't be the last time I need your help.
Thanks,
Jim
One of those great Holley regulators that barely changed from the ‘60s? If you’ve already got a good one, I sort of doubt that’s the problem, but you never know. How long have you owned the car? Can you send a pic of that regulator setup?
Are you pretty darn sure the main lead from the ignition to the coil isn’t loose or internally broken? It’s an easy test. Put a voltmeter from ground to the ignition side of the coil, and wiggle that wire. I did it once after shutting down on the road, and the current jumped from 0 to .5 to 12, so I was lucky. I fixed the wire and spade connector at the coil.
I wouldn’t discount what Hamish and others said about a deteriorated rubber hose, but if gas gushes when you disconnect the hose at the pump, coming from the tank (have a catch pan ready, including under the car on the floor), those hoses might all be OK.
There are folks on this site who’d humble the best mechanics and body men you’ll find anywhere. I was just eyeballing a member’s restoration project and wondering how many lives I’d need to live to know how to do half of what this guy can do, and has done.
I put the fuel pressure gauge on today, from all I have been able to research it should be 2-3 psi. It read 4 psi, and I adjusted it to 3 psi. She still quit on me, but this time I took the top off the fuel bowl and it was dry. I'm thinking it could be fuel pump just quits or trash in tank. I will probably take tank out and make sure it is clean. I
Sorry, but we might need to scratch some of the thinking here. I forgot that you have a supercharger on that vehicle.
You also have an electric fuel pump.
I’m not certain, but I think the Moss kit included your pressure regulator and also had specs that suggested 4 to 4.5 psi to effectively run a supercharger.
The combined effect of the vacuum on the supercharger plus the extra psi measured at the regulator translates, I believe, to a slightly smaller or lesser pressure at the float needles inside your float chambers.
I am certainly no expert at all on superchargers, but from what you have been saying, my guess is that something is not set properly with your supercharger specifications, or you may even have a vacuum leak somewhere in that charger kit.
I’d make sure all of your gaskets and nuts and bolts are tight and that you don’t have a vacuum leak – – which you might be able to test for by spraying WD-40 near the gaskets while the engine is running. A drop or dramatic change in RPMs would tell you that there’s a leak.
Factory spec for a mechanical pump on a TR four is 1.5 psi to 2.5 psi. That spec has to do with the strength of the needles inside the float chamber, and the goal of never overpowering them.
If your float bowls are empty, as you say, your problem could be the direct opposite, meaning insufficient psi or a vacuum leak in that supercharger, or, perhaps, a faulty electric fuel pump. It could also be improper venting of the bowls, and I cannot tell from the photo you provided whether your supercharger kit came with special adapters to the standard SU carburetor fuel bowl lids that, by stock design, merely had a small hole bored into the top for venting.
Maybe start by trying to find the original specifications sheet for that supercharger and see what was said about the output of your electric fuel pump and psi measured at the carbs, and proper fuel bowl venting.
I guess this got more complicated?
I’d be interested in what you learn.
Thanks, I might try turning the pressure up and see what happens. Could this do anything other than maybe flood it out if it's too much?
I’d try 4.5 or 5 psi unless there’s more specific guidance in the supercharger information pamphlets.
I guess you do have your float bowls vented back into the air cleaners don’t you?
If, when using your fuel pressure gauge, the needle was steady and not bouncing around, then your fuel pump might be doing its job properly.
That Holley fuel regulator can reduce fuel pressure, but it can only increase it to what your pump is actually putting out. It may be useful for you to open up the pressure valve (which I think means turning it inward) and see what that pump is actually putting out prior to being regulated by your fuel pressure regulator.
If it’s putting out a 4.5 to 5, or even more, I wouldn’t see any harm in experimenting at 4.5 to 5 for the actual output to the carburetors, given that you do have that supercharger. Though, once again, it would be best if you had the written materials and specifications that came with that unit.
The only other thing I would say is from experience. Getting stuck on the road with flooded carburetors is no fun and can sometimes require a tow home with your neighbors grinning widely.
So you might not want to go for any drives, especially in the evening, until you know that engine is running properly.
PS Make sure those fuel bowl vent lines aren’t plugged up.
I think I will try cranking that pressure up tomorrow and see what happens. Thanks for all your info, I will let you know what happens.
Jimmy
FWIW, from your pic, that’s a lot of thread showing in that adjusting screw. The more thread, the lower the pressure setting. You do know that the auto shops carry a gauge that permanently fits, or screws, into the side of that Holley regulator. Mine cost me about $10. I think I sealed it in there with blue liquid teflon. The instructions say not to use teflon tape. Adjusting right there without having to set up your separate testing gauge makes it a lot easier. You may already have one attached. I couldn’t quite tell from the pic.
But that raises another thought. That’s a long run from your regulator to the carbs, and if that’s all rubber hose you could be losing pressure along the way. The stock steel line from the pump to the carbs avoided pressure loss. Not so sure long rubber lines won’t affect the physics. I wonder where you are measuring pressure. A reading way back on a rubber hose (three feet or more from the carbs) might be misleading. And a last point—are there any kinks in that rubber line. That bend from the regulator looks sharp to me.
At the risk of inundating all of us, here’s what I found on the Internet:
“If your supercharger is cramming 5 psi of air down into the carburetor, that 5 psi of air pressure pushes backward against the needle and seat inside your carburetor's float bowl. If your fuel line only has 3 psi of pressure, the air pressure wins. It blocks the fuel from entering, the float bowls run dry, and the engine starves.
To fix this, you connect a small, flexible air line (the vacuum/boost line) directly from the plenum (the pressurized chamber under or after the supercharger) to a little nipple on top of the fuel regulator called the Boost Reference Port.”
I can’t “vouch” for those comments, and I’m not even sure pressure regulators for these cars have boost ports. That may be an entirely different animal, and maybe Moss made it all easier. Either way, it looks like adding a supercharger made things a bit more complicated. I’d take a hard look first at those lines, the quality and type of lines, the routing, and the pressure. It seems likely your dry bowls are due to a combination of these issues.
