16-Valve Head for Minis/Sprites
aeronca65t
Wow!
A twin cam head for the 1275 Spridget or Mini!
This is not a Honda engine swap, it's a special 16-valve head for the "A" block engine.
From 130 HP up to 190 depending on how deep your pockets are. The more powerful engine conversion is about $10,000 USD
Info:
https://www.kad-uk.com/engine.htm
G
Yep, I ran across that site about 2 years ago. Mighty expensive conversion!
78Z
Neat but impractical for most people on the cost basis. There are new 3 valve per cylinder heads for the Chevy small block V8 that bolt on with no other modifications (so still push rod). Would be neat to something like that. Of course the aftermarket for SBC is huge ...
Mark Beiser
[ QUOTE ]
The more powerful engine conversion is about $10,000[/image]
[/ QUOTE ]
Look again, that isn't $10,000, that is £10,000! /ubbthreads/images/graemlins/eek.gif
pbraun
KAD does some really nice stuff!
ValveFloatLimted
yeah you can buy that through 7enterprises for $6800 for the street or $7500 race or $14K for the whole engine then just slap a supercharger on there....
RickAnderson
Jack Knight also made a 16V conversion that was available in the 90s and there was also a BMW motorcycle head conversion that required very little machining to fit the A-Series block.
Has anybody seen the new 7-port head by Mini Spares? It is the same principal as the early 8-port head with the intake in front and exhaust in back. But the 8-port heads required a special cam where the 7-port heads will work with any off-the-shelf cam.
ValveFloatLimted
Ive heard of the 7 port, they were doing a build up a while ago in either mini magazine or mini world can't remeber now and they were using the 7 port for the same reason Rick mentioned, you can use standard cams which gives a lot more options.
EMGEBE
hi guys.
I dont normally post in other forums other than the MG ones, but this post got me curious.
Does a 16 valve head exist for the larger 1800 engines from my B?
Jarrod.
/ubbthreads/images/graemlins/thumbsup.gif
Dozuki
Quote from 78Z:"There are new 3 valve per cylinder heads for the Chevy small block V8 that bolt on with no other modifications (so still push rod)."
I'd like to know more about this, do you have any links or info?
-D.
Simon TR4a
Jarrod, you can get very nice alloy crossflow heads for the "B", with 8 ports, and a guy named Hans Pedersen, based in Oz I believe, sells a supercharger kit.
Over here in North America there is a lot of interest in the Moss supercharger kit.
I am not aware of 16 valve heads.
Simon
RickAnderson
Here is a photo of the new Minisport head. Notice that it is a crossflow design - the front of the head has flanges for a pair of Webers or four Amal carbs while the back side uses the same exhaust header. Although not quite as good as an 8 port head, it is much cheaper to use - regular cam, valve train, and header, etc.
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
K TR2/3/3A Cylinder head valve springs? Triumph 3
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
T TR2/3/3A Cyclinder Head work and valve guide issue Triumph 2
Marvin Gruber TR2/3/3A TR2 low port head valve? Triumph 2
Brosky Cylinder head machine, valve job & CC Triumph 10
B 18v Block and Big Valve Head for sale in SoCal MG 2
Jayrz 16 Valve head,,, Oh Good Lord! Spridgets 16
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
