TR4/4A tr4 pops out of second gear on deceleration
Onefuntr4
My tr4 pops out of second gear under deceleration.
Everything else is good with the transmission.
Thanks for the help
DavidApp
Mine does the same thing.
It has been suggested that it is either the "Top Hat Bronze bush" that is worn or the synchro rings are worn. Either way fixing that would require the gear box to be removed.
I have found an OD transmission and plan a winter install.
David
mgedit
What fluid are you using? When I used Redline in mine I had a similar issue. Switching to 30 nondetergent motor oil cured my problem (was a newly rebuilt J-type OD). This was several years ago. Cheers, Mike
Graham H
It could be the selector fork or a problem with the detent ball on the shaft or one of the springs and balls in the gear slider has broken and fallen out. If the problem is in the selectors you can fix it with the box in if the problem is in the gear slider you will have to take the box out.
Graham
TomMull
Graham
If it's in the selector, you can sometimes hold it in gear with the shift lever. If it's the top hat, you can't. Tom
TR4nut
I had that same issue, was convinced it was the 2nd gear bush as I had seen several broken previously and I didn’t test per Toms suggestion. All mine was was was a weak spring on the selector shaft.
sp53
I have gone back and forth with same kind of issue for 20 years on this one trans. Does anyone know how tight to make those 3 springs and balls deal on the back of the shifting tower or are you taking about the ball that goes in on its side in the tower between the 2 shafts? In addition, I remember a post where the discussion was about the O rings on the shafts and how they are difficult to seal and the correct O rings had to be improvised somehow. Mine pops out going downhill only and leaks, something like tightening up or replacing the spring and ball would not surprise me for a fix-- plus I have the trans cover off so now would be a good time.
steve
TR4nut
I adjusted the ones on the end - easy to do in my case because I had the screw in plug style. I didn’t get fancy with measuring any kind of release tension, just tightened down more and tried it out.
sp53
Does the “screw in plug style” mean that you have access to the screw with the shifting tower on the car and in place? On my tr3 I need to pull the tower off and flip it over and then are 3 screws in the back that can be screw down to put more pressure on the shaft.
TR4nut
No you still have to pull the cover - later covers, I think later TR6 had small freeze plug style plugs instead of the screw in plugs which seem to me to be more of a pain to deal with.
TomMull
Interesting, I've never tried to "adjust" those screws, instead I've left them very slightly lower than the surface, as they seemed to be when I took them out. I also find no mention of adjustment in the Service Manual. I suppose there is no harm in screwing them in more to put more tension on the springs but there's really nothing to hold them in place (loctite maybe). But from my experience, they should work properly just below the surface and will be held in place by the mating surface on the transmission. But if screwing them in tighter works, that might at least prolong the required rebuild, which would be a good thing.
From what I gather, the newer style plugs are best replaced by tapping the housing and using the threaded type. Also kind of fun to remove or so I'm told.
Tom
Joe Schlosser
Any time I have had poping out of 2nd (not truimph) it was worn synchros.
Graham H
It's the synchro hub with it's spring loaded balls that hold the gears in mesh, the box would have to be well worn for that to be the problem but still possible
Graham.
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
