Results 1 to 3 of 3
Thread: Lotus Elan S4, From water pump...to a strip down..
Discussions of Lotus Sports Cars
  1. #1
    Join Date
    Feb 2019
    Location
    Birmingham
    Posts
    5
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Last spring I decided to change the water pump in my Elan, that means head off! Then I decided saw that the exhaust valve guides were weeping slightly.....and it's gone on from there to most of the car currently in bits....
    https://youtu.be/noQ-YWJgtkI
    Suspension removal https://youtu.be/mqgJH9yhS9s
    Dash removal https://youtu.be/0Bu7T6El8qM
    Interior removal https://youtu.be/fK-0OzCNczM
    ....and so it goes on probably for another 12 months or so.
  2. #2
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,334
    Thanks Thanks Given
    47
    78
    Thanked in
    Re: Lotus Elan S4, From water pump...to a strip down..
    Welcome to the Forum, djb222! Keep posting progress! Maybe we can reinvigorate the Lotus section of the Forum.
    S-4, retro-fitted with DCOE's! Nice. Spyder frame?!? You lucky guy! My original frame has been bent and straightened (1975), now cracked laterally at the rear, where the diff steady rods attach, after impact at speed with a piece of steel beam in the passing lane of an Interstate highway... a Spyder frame costs as much to ship here to the Colonies as the frame itself! Gearing up now for a second frame-off for the S-3. May opt to patch the original frame and continue to wish for a Lottery win.
    Water pump. Know the job intimately. It can be done without head removal, but that's tedious. I've done Europa T/C ones on a lift from underneath, without pulling the head, as well as Elans.
    And your "pile" is totally familiar! I recently fitted an alternator to our MGB, will do the same with the Elans when the time comes. A worthwhile 'conversion'.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  3. #3
    Join Date
    Feb 2019
    Location
    Birmingham
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Thanks for your comments, I've now decided to strip the paint. See other thread..
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
