Mike Stobbe
I've got an Europa mystery. The spiral pins on my Twin Cam have started backing out. This has never happened before. The pins are about 1/4" longer than the U-Joint yolk diameter. I'm careful when installing them to have 1/8" sticking out on each end, but now in about 50 miles of driving both pins move 1/8", flush on one end and sticking out 1/4" on the other. I haven't dared drive farther to see if they will continue moving; I assume they will. They aren't loose. It takes a ball peen hammer and a drift to reset them. And I thought I was being very careful to shim out the yolk with no end float or even a bit of interference fit. Have any Europa owners out there experienced this? I've got maybe 10,000 miles of Europa experience, but never this problem before.
