M_Pied_Lourd
Hi Guys,
Spent the past week on a new problem...at least I think it's a problem....
The background
I can idle the car for about 12 minutes before it starts to run rough from what I think is fuel percolation/vapour lock.
The car never goes about 195 F as I have an electric fan on a new wizard aluminum rad that kicks in at about 185 F. The problem happens when the puller fan kicks on it brings quite a bit of hot air from the radiator into the engine bay. The fan works to pull the temperature back down to about 170 before it cycles off. The problem is in the interm between the cycles. The car has never overheated because the carbs start to run rough and eventually it won't idle well before it shuts off if I don't give it any throttle.
I think from what I've read, the car seems to be operating at about a fairly common temperature range when idling.
I can't get the car to run any cooler at idle...I've checked timing, installed a 165 F thermostat and added a drilled plug to the bypass hose. I've flushed the block twice and refilled with 50/50 water coolant. I've checked mixture on the carbs and made sure needles are not binding etc...
I should mention that I am running a stainless header that I have wrapped with header wrap. I'm sure this contributes to some Under hood heat as well, but like I said, temp guage never goes above 195 F.
I'm not sure how this will effect the drive ability of the car as idling in the garage is one thing...actual road testing/driving it, this might be a non issue unless I get stuck in heavy traffic.
Any thoughts on a cure for my rough idle? I was thinking a heat shield might be helpful for the stock SU's but though I would ask here first.
Cheers
Tush
The background
Cheers
Tush
