TR6 ZS 175 Mod. 3292 rebuild [70TR6]
Jmor
Need help! Bentley manual is useless. My carbs have fixed jets and fixed needles. Both are worn.
Questions:
I. Haynes manual states "the jet assembly is pressed into the body and is not adjustable or removeable".
Contradiction: Moss sells a master rebuild kit that "includes jets for all models from 1970 on". (Brit Vic ain't got a clue). So I assume the jet CAN be removed and replaced.
A) What's the best way to press the old jet out?
B) How do you press the new one in?
C) Is the new jet set flush to the bridge? My old jet positions show two concentric "step downs" from the bridge i.e., two concentric levels or platforms--the center step down being the deepest or lowest. (Jet within a jet holder within the jet bore?)
II. Metering needle
Haynes manual states fixed needle assembly fits into a socket in the air valve guide rod.
A) My needles are stuck--can't be pulled out with fingers (the car sat for 8 years). Can they be pressed (forced) out by inserting a steel rod down thru the air valve guide rod? Will a retaining clip prevent this (assuming there is one--see next item)?
B. Should I assume the retaining clip (Moss part #365-395) which the Moss catalog says is needed for my model 3292 is actually not needed? Why would you need a retaining clip if the needle locking screw holds it in place--it's a fixed needle assembly. If there is one, how do you get it out and the new one in?
III. Tuning
Since the jets and metering needles are fixed, is there any other way to fine tune idle and/or A/F ratio? Or will that be unnecessary?
IV Vacuum Port Connections
Rear carb has 3 vacuum port connections. Bottom port goes to distributor advance; front/side port goes to valve cover (Via T-fitting)--where does the top port go?
Thanks so much for your help. This is a fantastic bulleting board!
trboost
I'm no expert in this. To cut your learning curve time I would call upon the expertise of Joe Curto, Queens N.Y. Absolutly no financial interest just a nice guy who knows british carbs. https://www.joecurto.com/
I see him at many of the shows, always willing to help & has a vast inventory.
vrod
I have a tr250 which should have the same carbs as yours and I changed my needle carier over to the late model carb needle cariers that are adjustable. Its been a while since I did this, but from what I recall I think I had to grind the tr250 carier in order to release the needle install it into the late model carier it was all very easy and I've had air/fuel adjustable carbs ever since.
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
P MGB Zenith 175 cd carb damper oil MG 2
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Pythias 175/70 13s. Pirelli! Spridgets 7
C TR6 ZS 175 What does this screw do? Triumph 2
B For Sale 175 CD Strombergs Triumph Classifieds 0
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
aeronca65t BSA 175 Bantam British Motorbikes 2
J MGB Are 175 tires the widest that will fit onto a MGB?? MG 3
J TR4/4A 175 CD needle position? Triumph 5
L Stromberg 175 cd question Other British Cars 5
A Zenith 175 CD's Triumph 19
R Zenith Stromberg CD 175 float replacements? Triumph 3
M stromberg 175 cd? Triumph 5
M stromberg 175 choke cable? Triumph 2
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175 cd. Triumph 7
B where to buy 175/80r15's? Austin Healey 11
T Hap - 175/70/13 or 185/70/13 for your Superlights? Spridgets 26
ncbugeye Problem: Bugeye and 175/70 tyres on SuperLite rims Spridgets 1
mrv8q Couple ZS 175 questions Triumph 9
H Zenith Stromberg CD 175 Too rich Triumph 7
Brooklands Air Filter for Stromberg 175's Triumph 3
E Stromberg 175 idle Triumph 2
1 175/70/14 tires, yay or nay? MG 15
philman FREE ZS 175 Carburettors [front and rear] Triumph 2
J Zenith Stromburg 175 carburator tune? Other British Cars 3
R Zenith 175 CD Choke Triumph 0
H stromberg 175 carbs Jaguar 1
jerrybny TR6 73 TR6 ZS 175 CD-2 carb question Triumph 6
W What is the proper procedure for priming S.U.175's Triumph 4
Hegg Carburetor Detective Work 175 CD and 175 CD2 Triumph 3
HealeyPassion Rear bumper mod.... Austin Healey 5
Basil Admin Note Please Mark sold items! Also - Cool new Mod for our Classifieds forums Austin Healey Classifieds 1
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
B Everything runs better with this mod - all models!!! Spridgets 7
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
JPSmit MGB-GT Hey Mickey - here's a mod for the GT MG 10
andrea LONGBRIDGE cars SOFT TOP -MOD safe water seapage Austin Healey 16
5 The scuttle shake mod- I can't decide Austin Healey 7
C 100-6 Resto-Mod Nasty-Boy Brake Upgrade - Help... Austin Healey 2
t_bush Washer "Pump" switch to electric mod. Triumph 1
P Air filter securing mod Austin Healey 11
C Need someone to mod my rvi tach for ele ignition Spridgets 2
bighealeysource Spin on filter mod for BT7 Austin Healey 11
Brosky TR6 Konig 15X7 wheels on TR6 - No mod fit? Triumph 22
