Carburetor Detective Work 175 CD and 175 CD2
Hegg
Greetings, friends!
I have a 1980 model year (mfg in 1979) TR7 that I *think* is pretty much stock-ish. I have obtained an additional intake manifold and carb assembly that was claimed to be a 1980. However, I'm not exactly sure what I have right now.
I have taken several pictures and posted them at
https://unabled.com/show/cars/tr7/carbs/. The ones on the car are the "original_" ones and the new intakes are the "new_" ones.
First of all, The new set doesn't seem to have a choke system that I can readily see. Secondly, the breather rail assembly seems to match the 1975-1976 layout -- according to my parts book. Thirdly, the new one doesn't have the EGR valve thingy on it, and the intake casting seems to be slightly different. The underside of the new set also has a removable valve of some sort.
All of these things make me think "hmm... this is probably an older carb set up than my 1980 is". However, if you take a look at the "closeup" pictures, you'll see that my stock system has the Stromberg 175CD, while the new one I have is the Stromberg 175CD2. One would assume that the CD2 came after the CD.
Anyway, does anyone recognize either set up and can tell me anything about them? Which set is better? What do I do about the choke system in the event that the CD2 is a nicer carb setup to use?
Seems like kind of a detective story to me, but probably not as humerous as the fellow that lost the bolt from underneath his Triumph.
Mark Beiser
The new manafold and carb setup you got is Canadian spec with manual choke. The EGR valve is there, but the round part with the vaccume diaphragm is broken off.
You can use it, but you would have to get your hands on a double choke cable from an early model, or later Canadian spec car, and mount it under the dash. You would also need to do some rerouting of heater hoses and possibly change throtle cables.
There is no functional difference between a 175CD and 175CD-2 carburetor as far as your engine performance is concerned. IMO, your better off sticking with your stock setup and purchasing one of the nice manual choke conversion kits sold by just about every British parts supplier.
[ 01-30-2004: Message edited by: Mark Beiser ]</p>
Hegg
Hegg
AAaaaah, so it's a Canadian one!
My stock setup already has a manual choke all hooked up and working just dandy (I like it), so I'll just keep with that.
Now I just hafta wait for my rebuilt kit to get here!
Thanks for the info,
Hegg
steve99
Hegg,
I also have a 1980 (Mfg 6/79) TR7. My existing setup appears to be same as yours, my auto choke still works. I rebuilt carbs last summer, pretty straight forward. I would recommend purchasing the Weber carb manual that has a fairly extensive section on the ZS carbs.
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
SMGoose Carburetor piston not falling freely Triumph 7
