Zero oil pressure at 4000 RPM
Jurjen
Is it in any way possible a broken piston pin circlip can stop the oil circulation and cause a 100% drop of oil pressure when driving at 85 MPH?
(Edit) Some details:
- Freshly rebuilt MK3 engine; 4,000 miles driven
- Sudden loss of power driving at 80 - 90 MPH / 3,000 - 4,000 RPM
- Zero oil pressure on gauge
- After cooling down, the engine still ran (oil pressure was up, but lower than normal)
After pulling the engine:
- Piston/gudgeon pin circlip 2nd cylinder broken (see pictures)
- 2nd cylinder damaged
- All bearings worn (bearings at 6th cylinder show the most wear - 1st cylinder bearings - main and rod - look ok)
I'm trying to find out what happened, because I don't want to pay for a new rebuild.
bob hughes
Re: Zero oil pressure at 4.000 RPM
I guess that it could depend on where that broken piece ended up.
That is extremely unlucky.
The real question is why did it break? Installed correctly - there should be very little stress on that part.
Have a look inside your oil pump and see what the parts look like, the strainer should have stopped anything large from entering, have you found all the bits of the circlip?
:cheers:
J
Jurjen
No, I didn't find all the bits and the strainer was on the pump.
Nobody knows why the circlip broke, but the engine builder will repair the damage to the piston and cylinder free of charge. The damage to the crank though, I have to pay myself because it's uncorrelated, supposedly. I know next to nothing, but have some doubts.
For me, this is about finding an argument to convince the builder there is a scenario where both issues are correlated.
dancrim
Sounds like that motor got too hot. 2 reasons for that: Water pump failed or oil pump failed. Either
would cause crank bearings to start to seize and act like a loss of power. Pistons become too tight
in the bore and this can cause the clip to pop out. Be sure to check the oil pump for a sheered gear key.
Can you be sure the pump didn't loose pressure just before the power loss. At 85 we normally don't
have our eyes on the gauge and it would only take a minute to seize things up.
J
Jurjen
Thanks for the replies!
Yes, the dip of oil pressure could have well happened just before the loss of power. It was only after the car slowed down, that I looked at the gauge and stopped the car.
The engine getting too hot is another scenario. But it’s hard to say what caused it to overheat at that moment, now the engine is out. The 2,500 miles in summerly Italy before the breakdown were without any heating problems.
The oil pump is still looking good by the way.
And the cylinder was badly damaged by the circlip. I don't know how long it takes for that to happen?
Is that excessive carbon buildup on the piston (asking because I don't know, but wouldn't expect that on a low-time engine)? Would that be a clue?
J
Jurjen
Good question, I don't know whether it is excessive.
On this piston (the 2nd) the carbon was partly washed of, due to the head gasket being blown after the overheating/breakdown. Altogether I have driven the car for 100 miles after that (on different occasions, trying to figure out what was the problem).
dancrim
As a note, you might want to get caps that fit into the piston pin holes
as a safety measure. Not sure if they replace the clips or are just to
prevent damage if a clip fails. Man, that engine did overheat. The
head will have to be checked and possibly be resurfaced. I once had
a motor act the same many years ago. After cooling it started. Turned
out to be a overheating problem but I forgot if it was the water pump
or not. Luckily I stopped before any real damage was done. Once the
motor is at operating Temp. it would only take a mile to lock it up.
By the way, I worked for Philips many years and had to travel to
Eindhoven quite a few times. Good luck with your motor.
Here's a couple photos of 2 pistons removed from my BJ8 engine at overhaul (one was cleaned-up for inspection). These pistons had about 100K miles on them since a prior overhaul, and they probably had about 150K miles total (I don't remember if we cleaned them up when we reused them). So, the carbon buildup on yours may not be excessive:
I vaguely recall when we did the first overhaul the pistons had a lighter-colored, dry-appearing coating on top that didn't have the dark, oily appearance of these. But, at that time I was still running on mostly ethanol-free gas.
Patrick67BJ8
If you checked your oil pump and it’s good I’d check the oil pressure relief valve next.
Jim 58 BN6
That's a really good idea. About 40 years ago, I was flying down Interstate 280 just south of San Mateo/Belmont, in my original TR4 . The oil pressure suddenly went to zero. Fortunately, I saw it and shut the engine down and coasted to the shoulder. I found about 1/4 of a rather large (~1" dia) internal tooth washer blocking open the pressure relief valve (kind of similar to part of a piston pin clip??). It looked like nothing I remember seeing when I had put the engine together from a box of parts about a month before, and I had just driven the car from Northern New Mexico to the Bay Area. At least it didn't happen in ELY, NV! I reassembled the valve, the oil pressure came back, and I never had that problem again. I never did figure out where the 1/4 of a washer came from. :eek:
Good luck getting your car sorted out and back on the road.
Michael Oritt
Jurjen--
Naturally we are only able to speculate on what happened but if I understand post #7 correctly the fact that you have operated the engine for an appreciable amount of time since the incident is going to make it very hard to reach a definitive answer as to what failed first, etc. etc. I could be very wrong but I'm with dancrim when he says that the circlip's becoming dislodged was a result, not a cause.
BigGreen
... For me, this is about finding an argument to convince the builder there is a scenario where both issues are correlated.
... Altogether I have driven the car for 100 miles after that (on different occasions, trying to figure out what was the problem).
Not a good combination.
Was the builder a Healey expert ? Thought about a second opinion by one of the builders known by the AHOCN ?
J
Jurjen
No, not a good combination at all. But after the breakdown it was serviced by a respectable mechanic who couldn’t find anything unusual. It was only after 100 miles of strange behavior (as the owner, you know when something is wrong) I thought it best to pull the engine. I spoke to a lot of connoisseurs about this, including some AHOCN people.
But alas, thanks for all the reactions; I think I have my answer: bite the bullet, pay the bill and drive the car.
I've learned so much the past few months, whatever it was that caused the failure, it won’t happen again.
Or will... I don’t know. But in that case, I’ll repair it myself!
Michael Oritt
What happened to Jurjen might have been prevented by a prominently-displayed "idiot light" wired to a normally-open 5-10 psi switch plumbed into the oil flex line.
Warning lights got a bad rap when manufacturers tried to do away with or marginalize gauges. However when the OP gauge is not prominently mounted in our line of sight, as is the case with the "Safety Gauge" supplied on our cars, it is easy to miss seeing the needle plunging to zero or waivering as bearings fail/spin, etc.
Because I have a Smitty's five speed the hole for the OD switch offered me a great place to mount such a light and though it is below my line of sight it is big enough to be in my peripheral vision and catch my eye. I know many owners are averse to drilling holes in their dash fascias and there are other options. In any case the stakes are high as this topic demonstrates.
J
Jurjen
That's actually the first thing I will do when I get the engine back. Install an oil pressure switch and drill a big hole right next to the indicator light.
dancrim
The "idiot" light is a "better" but a sonar alert is best. Emits a high pitched sound.
Again, will you notice a light going on when driving? Especially in the summer sun?
If the sonar alert goes off, you WILL notice it. They are cheap, 12v. and as easy
to wire as a light. Again, I see you tested the oil pump, be sure you keep a good
eye on the Temp. gauge as well once you run the car.
GeorgeC
Will these sonar alerts work with positive earth?
steveg
How about a link? All I could find was OEM switch replacements. Will they work if attached to a 12V buzzer?
K Zero oil pressure Austin Healey 36
Mark_Barton Oil Pressure Gauge not returning to zero Triumph 11
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
Bob Claffie Tiger project , phaze zero Sunbeam (Rootes) 17
H POR-15 is BAD use Zero-Rust instead Triumph 60
4aKen zero to 60 Triumph 6
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
